Homelink issue. Two Prius. Can both operate garage door?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Ray Moore, May 16, 2005.
  1. Ray Moore
    Ray Moore Active Member
    857
    52
    Texas Hill Country
    I programmed my wife's new Prius to open the garage door but now mine has stopped working. We have a garage door with rolling codes. Has anyone encountered this before and is there a fix?
  2. Tideland Prius
    16,155
    I have both the Prius and the Camry programmed to the garage door opener and both work. It's also a rolling code. Not sure if there's a difference in the Homelink between the Prius and the Camry.
  3. sanguis
    sanguis Member
    103
    WA
    how many garage door openers do you have? If you have two, you can use two different ones to program your homelinks separately so that the openers rolling codes roll independantly?
  4. Ray Moore
    857
    52
    Texas Hill Country
    Alas. We have but one opener. Good idea though.
  5. nmrickie
    nmrickie Member
    200
    New Mexico
    My Prius and 350Z Homelinks open the same door.
  6. Tadashi
    Tadashi Member
    796
    Fort Hood, TX
    My Prius and my wife's opens up our garage door. Did you try to set it away from your garage. When I tried to set both inside the garage it had problems. I had to drive it out of range and do it.
  7. Ray Moore
    857
    52
    Texas Hill Country
    Do ya'll have a rolling code door?
  8. nmrickie
    nmrickie Member
    200
    New Mexico
    <div class='quotetop'>QUOTE(Ray Moore\";p=\"90157)</div>
    Yes, in fact come to think of it I have 3 vehicles that open the same door (2 with Homelink and one regular transmitter).
    Have you tried reprogramming them?
  9. inventor00
    inventor00 Active Member
    1,131
    60
    Phoenix, AZ
    Three oddball hints: 1. Did your car go to the shop recently- sometimes they unhook the battery and I had to reset mine several times.
    2. For the Rolling codes, I had to put a new battery in the handheld remote (even though it worked fine) before it took, to program the Homelink.
    3. I pressed once too long on the garage door opener button(attached to the garage) and reset all the codes, so no opener would work except the one I just set... oops.
  10. DanMan32
    DanMan32 Senior Member
    3,799
    26
    Tampa Bay, FL
    If your garage door is rolling code, find out how many remotes it can support. The homelink simply subs for a remote, and will use up one of the 'slots' in the opener.
  11. Rowan
    Rowan Junior Member
    34
    Carrollton, TX
    I think DanMan32 is on the right track. I had a similar problem sometime back and it ended up that the door opener just had too many remotes trained to it. I ended up reseting the main unit and retrained each remote again to it and everything now works again.
  12. kristenl
    kristenl New Member
    Illinois
    Were you ever able to find a fix to this issue? I tired to program mine and it worked but then my husbands didn't. I then did his and then mine didn't work. Is it not possible to program 2 different cars onto one garage door opener?
  13. devprius
    devprius /dev/geek
    979
    291
    San Francisco Bay Area, CA
    We have a Sienna & a Prius and both are able to operate the garage doors without a problem.
    I seem to recall the sequence of events was to:
    a) press and hold the Homelink button you want to program while at the same time holding and pressing the remote that came with the garage door opener. Homelink button should light up and blink indicating it has learned from the other remote.
    b) on the garage door opener itself, press the learn button
    c) within 30 seconds, press the Homelink button you just programmed via the original remote. Garage door opener light should blink several times indicating that it has learned the new remote.
