Homelink losing strength?
Discussion in 'Gen 2 Prius Main Forum' started by Ghostrider, Jan 4, 2007.
  1. Ghostrider
    Ghostrider New Member
    121
    I have the homelink on my 2006 since Sept. Until last week I could open the garage door while coming up to the house and still in the street. Now I have to be in the driveway and almost at the door. I have checked and the antennae is hanging and not obstructed. Anyone have any idea why the range is cut in half? Also is there
    a way to measure this so I can determine if the homelink is bad. I have programmed two buttons with the same door and have the issue with both.
  2. Tideland Prius
    16,445
    hmm, not sure. My 05 still works fine and I can have the garage fully opened by the time I reach the door as I drive up/down the alley.
  3. Presto
    Presto Has his homepage set to PC
    1,326
    24
    Vancouver, BC
    I have noticed a varying Homelink range. Usually, I can open the garage door right after turning onto my street. Sporadically, I may have to cut the distance in half to get it to work. I blame it on the weather :p
  4. auricchio
    auricchio Member
    921
    Cambria, CA, USA
    Homelink works on the 288 to 399MHz frequency band, and some units go to 418MHz.
    I suspect some local RF interference, though I don't know what could be the cause. Wireiess networking is at the 2.4GHz band, so that isn't it.
  5. volkl
    volkl Junior Member
    I too have noticed a less than expected range, and a diminished range for my homelink garage door opener.
    Perhaps the Patriot Act or broad domestic wiretapping without judicial oversight is the cause. Yahtzee!
  6. auricchio
    auricchio Member
    921
    Cambria, CA, USA
    It appears there are also several mobile radio services that may operate in the 300MHz band, which could account for occasional interference.
    There's a rather good chart at http://www.ntia.doc.gov/osmhome/allochrt.pdf
  7. qbee42
    qbee42 My other car is a boat
    18,058
    3,076
    Northern Michigan
    I agree it's most likely local RF interference - not much you can do about that.
    Tom
  8. Charles Suitt
    Charles Suitt Senior Member
    1,637
    17
    Dallas TX
    :rolleyes: Programming "Homelink" to open my garage door took 3 efforts... the instructions are quite specific. Took similar tries to get the backup buzzer turned off.
    I had been accustomed to merely 'touching' the button my my 'clip on' opener control, but found that for 'Homelink' to work consistently I need to hold down the button for ½ to 1 second [until the indication light 'flashes']. Seems to work from about 150'.
  9. Ghostrider
    121
    Yes I always have to hold the button for about a second. I just have to hold it after turning in the driveway now. However today was much clearer than the past two weeks and it actually worked as I was turning in so I am starting to think that the weather with homelink is much diffferent than the weather with a remote transmitter.
