Homelite Mirror Install
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Paul V, Dec 25, 2013.
  1. Paul V
    Paul V New Member
    How do I install a factory homelite mirror in my 2012 prius
  2. AllanM
    AllanM New Member
    23
  3. Priusmpg
    Priusmpg Active Member
    628
    108
    Fremont, California
    2014 Prius Plug-in
    do you mean homelink?
  4. priusnoob78
    priusnoob78 Junior Member
    23
    2014 Prius Plug-in
    I was able to install this on my 2014 prius plug in base model. I did this whole thing without unplugging the 12V battery.
    Some notes that I think would make it easier for plug ins.
    I was able to buy one for 2nd gen prius and it worked on my 3rd gen plug in. Mine came with a harness that had the wires cut. I simply attached 3 wires, soldered and electrical taped them.
    My stock mirror that came with my car, people say just pull upwards, actually there is a little button on the bottom, you have to push it inwards (towards the cabin) with a big flat screw driver, before pulling up on the mirror.
    The ground and constant 12V you tap from the overhead lights as indicated in the PDF manual file.
    So you actually only have to route 1 wire through the headliner, down the driver side pillar and behind the outside mirror control button.
    To get access to the outside mirror control button, you pull the left kick panel from the top enough so you can get a screw driver in and remove the 1 screw out (careful not to drop behind the kick panel. Once that one screw is out, you simply pull the panel off but not too hard because it is still attached to the hood release cord. Unclip the 10pin outside mirror control and tap into the grey wire for 12V ACC.
    hope that helps.
  5. JC91006
    16,480
    8,397
    Pm usnavystcg he's done this many times
    SM-N900P ?
