Honda Hybrid IMA - No ability move without ICE on, correct?
Discussion in 'Honda/Acura Hybrids and EVs' started by cycledrum, Apr 30, 2011.
  1. cycledrum
    cycledrum PSOCSOASP
    8,245
    1,202
    NorCal
    One of the great characteristics of Toyota's Hybrid Synergy Drive is the ability for the vehicle to move on battery power alone.
    Case in point - you enter a parking lot, spaces hard to find, less stress in Prius because you are creeping around the lot on battery power..
    or the drive through..
    or in the terrible traffic jam
    Isn't it true that every time you want to move even one foot in an IMA car, the ICE kicks on because it has to kick on to move the car?
  2. Hal W
    Hal W New Member
    872
    53
    Grand Forks,B.C. Canada
    Correct. Only has a 20 hp electric mtr. I believe the Prius has 60 in the G2. Hal
  3. ernestmurphyiii
    ernestmurphyiii Junior Member
    Washington state
    Just drove my girlfriend's new Honda Jazz hybrid for the first time. The second you take your foot off the brake pedal, while stopped, the gas engine starts up. If there's a way to drive this car at any speed solely on the electric motor, I haven't figured it out yet.
  4. ericbecky
    ericbecky Hybrid Battery Hero
    4,371
    3,220
    Madison, Wisconsin
    The civic Hybrid does have an EV mode of sorts. Basically the valves get deactivated and turns the pistons into air springs. In this mode it takes very little energy to turn over the gasoline engine.
    Now, the upside of the IMA system is that if the battery ever dies, you can continue to drive the car indefinitely without any battery at all and use it as an efficient gas powered car.
    You can't do that in a Prius. In a Prius, when the battery dies, you will have to replace the battery or the car won't be able to move.
  5. Southern Dad
    Southern Dad Active Member
    350
    212
    58
    Monroe, GA
    I have both a first generation Honda Insight and a second generation Toyota Prius. They both have their good points and bad. One of the good points about the Toyota is the ability to move on battery only. One of the bad points about the Toyota Prius is that inability to drive it if the traction battery dies.
    My Honda Insight gets better mpg on the highway than in the city where the Toyota Prius loves stop & go and gets its best mpg in the city. In the Prius I can sneak up on someone only in EV when in a parking lot.
    The Prius has another big plus... The air conditioner keeps blowing when the ICE is not running. Not so in the Insight. Plus I love the Prius cruise control. That said, I still find my self driving the Insight more.
  6. luckyboy
    luckyboy Member
    204
    29
    Looking over the Insight brochure, it does say that it may move under electric power only under certain circumstances.
  7. ItsNotAboutTheMoney
    ItsNotAboutTheMoney EditProfOptInfoCustomUser Title
    2,287
    460
    Maine
    False. Think of it as a Prius with a small battery and higher minimum engine drag.
  8. Hal W
    Hal W New Member
    872
    53
    It is not false. You can travel in EV mode for some distance as long as your SOC is good and on the flats you can maintain your speed with electric only. You can use up to 4 rejen bars that will power you along! The Civic hybrid air is electric and works when in engine off mode. I have had very good luck with my Civic Hybrid, lots haven't. I personally prefer to drive it on trips versus the Prius. Prius kills it in town and for storage however. Hal
