Honda Recall 63099 unit of Civic, Civic Hybrid and Stream. Date: 6 September 2007.
Discussion in 'Honda/Acura Hybrids and EVs' started by vincent1449p, Sep 8, 2007.
  1. vincent1449p
    vincent1449p Active Member
    894
    331
    Singapore
    Just to update Honda owners:
    Honda Recall notification number 1935, date 6 September 2007
    http://www.honda.co.jp/recall/070906_1935.html
    http://translate.google.com/translate?hl=e...70906_1935.html
    Recall parts name:
    1. Brake switch.
    Affected area: At telescopic steering wheel (front and back position of the rack). The clips may get loose and the lubricant may drip to the brake switch insulation. A continuous leak and the heat may damage the insulator on the particular contact point. When it becomes defective, there is a possibility that the stop lamp may stop lighting up. In a serious case, user may not operate the select transmission lever.
    Contents of improvement measure:
    Brake switch set and the electric wiring side connector are exchanged with the new item. The electric wiring side terminal is cleaned and the brake switch cover is added.
    2. Speedometer (computer control)
    Because the computer program that controls the speedometer and such is inadequate, after turning off the ignition switch, when it turns on again, there are times when processing control of the speedometer is not done. Because of that, there is a possibility the speedometer and the like to stop operating.
    Speedometer set is exchanged with the measured item.
