Honest opinion. Is this a bad idea? High mileage job
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by berderder, Jul 3, 2020.
  1. berderder
    berderder Junior Member
    61
    Connecticut
    Hi everyone,
    I drive a 2014 Prius 2 with 118,000 miles on it.
    I'm a property inspector. Which means I am driving about 6 hours a day going from property to property, with the majority of my time on the road as the job requires simple snapshots with my phone from the curb to check conditions, building codes, etc.
    I rack up about 2500 miles a month. I am not very DIY saavy although I am trying.
    So far I've spent about $2200 on repairs at the dealer since January 1 of this year. And I have only been doing the job for 6 months as an independent contractor.
    Is this job just not feasible with the wear and tear I'm putting on my vehicle? Should I consider doing something else?
  2. Raytheeagle
    Raytheeagle Senior Member
    11,251
    15,476
    Bay Area, California
    2019 Prius Prime
    What's the job you are considering :whistle:?
    What jobs have you done since January?
    What is the history of your Prius?
    Good luck and keep us posted(y).
    Grit likes this.
  3. Leadfoot J. McCoalroller
    6,803
    6,455
    Pennsylvania
    2018 Prius c
    A Prius is a major mile absorber; better than just about anything. In theory you've got the ideal car for that task.
    What's the dealer been charging you for? Every car needs maintenance, maintenance costs something and dealership maintenance is the highest-priced kind, but it still seems steep.
    Grit and berderder like this.
    48,947
    depends on what the job pays. a qualified inspector should make decent money.
    a prius at 118k only required oil and filters and tires to this point. what repairs have they done?
    at 120k, you're going to be looking at a couple grand at the dealer
    Grit likes this.
  5. Montgomery
    Montgomery Senior Member
    2,254
    2,233
    Orange County, CA
    If you can find a local independent mechanic who knows how to repair and maintain a Prius, your charges might be slightly lower due to lower overhead. We all would need to know what type of repairs have been done since January.
    Grit likes this.
  6. berderder
    61
    Connecticut
    Hi everyone,
    Thanks for the replies.
    It's a pretty middle class job, I'd be lucky to make 40k at this rate. I pay expenses out of pocket. Next year if I work harder I can make more.
    So far history of my Prius:
    - New brake pads, rotors, drums: 4/24/20 @ 113,000 miles (~$850)
    - New timing change tensioner (apparently it was leaking): 4/24/20 @ 113,000 miles (~$300)
    - Oil change (synthetic): 4/24 @ 113,000
    - I'm getting new tires next week ($350 including labor at a independent shop instead of dealer)
    - Transmission service: 2/26/20 @ 108,000 miles
    - Tune up (i imagine spark plugs): 2/26/20 @ 108,000 miles
  7. Leadfoot J. McCoalroller
    6,803
    6,455
    Pennsylvania
    2018 Prius c
    I think I see what's going on- you appear to be trusting the dealer to tell you what the car needs, and they're helping themselves to your wallet along the way. It's likely more maintenance than your car needs but you probably have other uses for those dollars.
    Take the time to find your original owners' manual, find the recommended maintenance section. Identify the next likely interval for service. Take note of the actual procedure indicated. Then when you go in, you ask for that specific procedure.
    If you continue to go back and order from the "mileage menu" they will continue to eat you alive. When they ask your odometer reading and then point at that overhead display, that's the trap swinging closed.
    Also, find a neighborhood mechanic. Local friends & family recommendations count heavily here. Oil changes do not need to be done at dealership prices. Same goes for lots of work. You kind of want to be in the position where you take it to the cheaper guy first, and when he says he can't handle it is when you make an appointment at the dealer.
  8. KennyGS
    KennyGS Senior Member
    1,243
    1,044
    Keystone State
    I've never had my 2014 Prius to a dealer since driving it off the lot brand new. My local mechanic, who's worked on all my cars for early 30 years, has never run into an issue he couldn't handle (yet). I agree with LJM (above), find a good local mechanic, and stay away from the dealer. (y)
    berderder likes this.
  9. tvpierce
    tvpierce Senior Member
    949
    879
    Maine
    2013 Prius v wagon
    You got good car advice above, now some job advice.
    You’re driving 30k miles a year for a job that pays $40k. Those are not good numbers.
    The good news is that as an independent contractor you can deduct those miles @ 57.5 cents per mile. That’s a $17,250 deduction.
    In theory, that $17,250 is really just money you paid out in travel expenses. (car payments, gas, oil, maintenance, insurance, etc.)
    With your car, you’re probably still coming out ahead because the fuel efficiency and relative low maintenance costs.
    If you can do one or two more inspections per day, and then take the other advice given in this thread to decrease your vehicle maintenance costs, your numbers start to look much better.
    I agree with @Leadfoot J. McCoalroller your Prius is the ideal car for this job, if you can have it maintained somewhere other than the dealer.
    Good luck!
  10. ETC(SS)
    6,492
    Sounds like you and your dealer both are trying to make a good living with your Prius.
    You have one of the better cars for your job - probably one of the BEST.
    You just need to go to the University of PriusChat and unshackle yourself from the dealers service department.
    Start reading in this forum for an hour or two a night for any post that mentions Dealer and DIY, and watch some YouTube vids.
    Good Luck!
  11. Montgomery
    2,254
    2,233
    Orange County, CA
    I agree with TVpierce. Since I have been furloughed off my regular job, I have been doing real estate appraisal work. The trick is not to just keep accepting work as they email it to you, its to select jobs that make sense for your distance and time. You will get slammed with too many assignments that actually cost you too much time. Also, all your tools are complete write offs!! Laptop, software, measuring devices, cameras, oil changes, tires.........you get my drift. It may not look like you are making money, but you stand to get a huge refund if your taxes are done correctly.
    KennyGS, berderder and Mendel Leisk like this.
  12. Grit
    Grit Senior Member
    6,113
    4,040
    Wilkes Land
    The most important part of the equation was left out; income bracket. If you make over $100,000 then the most recent repairs won't even put a dent on your overall finances on the terms that you're not heavily in debt therefore you can always move up on car conveniently when ever you want. If you make less than $40,000 and still making payments and if those repairs are revolving, I'd save up for reliable car & get rid of the prius soon as I can. The good thing is that the repairs done were long term parts and not to be revisited every 5,000 or 10,000 mile interval maintenance, half of the fixes were the typical 100,000 mile items. I drive 2,100 miles a month and been doing for the last 2 years, I'm a essential worker so mine is still running back and forth with wear & tear during this time. I won't give out job career advice yet even though I once worked as a job career coach, there's not enough background information of what you've done professionally prior to what your doing. In other words we can't guide you to another direction if we don't know where you've been, jobs you want to avoid and where you want to go.
    #12 Grit, Jul 4, 2020
  13. mjoo
    mjoo Senior Member
    1,107
    1,311
    Michigan
    With that mileage It's very likely that the EGR system has some carbon buildup in it if not completely plugged up. Before putting lots of highway miles on your car I'd clean out that system for another 100k miles. It'll then give you better gas mileage and help keep the engine from overheating. The parts to clean are the EGR cooler, the EGR, the EGR tube, and the intake manifold.
    There are different ways to get this done. You can take the parts off yourself and clean them, or buy used parts and clean them, or brand new parts. If there's no way to swap parts yourself I'd find a trustworthy independent shop to take it to.
    While you're doing this a PCV catch can will help keep the intake manifold clean and prevent the common startup knock issue.
    pjksr02, Merkey, berderder and 2 others like this.
  14. berderder
    61
    Connecticut
    Should I ignore the 5,000 mile Maintenance Required notification on the dash? Just reset it as long as I’m doing regular preventative maintenance and no dashboard lights are going off?
    pjksr02 likes this.
  15. bisco
    48,947
    don't ignore anything. car should get an inspection every 5k, somewhere. rotate tires. oil and filter every 10k, cabin filter inspect/clean/replace every 15k, air filter inspect/clean/replace every 30k, etc. but yes, you can reset it.
    find your maintenance schedule and follow it. try to find an indy mech if you can.
  16. bisco
    48,947
    your list of work above looks fine to me except the chain tensioner leak, that was a ripoff. 4 oil changes in 118k doesn't sound right though.
    if they did plugs, you're due for all fluids soon.
    any car would need what you have put into service so far, and brakes times 3.
  17. bisco
    48,947
    what tires are you getting? they are semi important
  18. berderder
    61
    Connecticut
    On Wednesday I’m getting General AltiMax all season.
    How do you feel about brake flush? The fluid looks fine in the reservoir and I feel no braking problem. I can’t seem to find when last time it was replaced
  19. bisco
    48,947
    good tires iirc. i think there is a thread here.
    i would follow the maintenance schedule for brake flush and all other maint.
    pjksr02 and berderder like this.
  20. KennyGS
    1,243
    1,044
    Keystone State
    For me, every 5k maintenance is checking everything: fluid levels, filters, tread wear, etc. Every 10k maintenance is oil/filter, checking everything again, then any longer interval replacement items (per the manual).
