honking chatter under hood when put pressure on break pedal
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by DirkG, Aug 15, 2009.
  1. DirkG
    DirkG Junior Member
    Eugene, OR
    When I am stopped, even when the car is powered off, I get a "honk-honk" noise and sometimes "whoo whoo" sometimes both, noise under what seems like the middle of the hood. I cant tell where, but I can replicate the noise anytime by just adding or releasing slight brake pressure. I think it is getting worse. It use to do it very seldomly, or only if I made it do it on purpose. Now it does it just about every time I come to a stop, or just as I take off.
    Both dealerships say they have never heard of anything like this and that it must be my breaks squealing because they have reached the wear indicator. I had to tell each of them 3 times that it happened once the car was stopped or even powered off. They still say its break grind.
    I have done enough break jobs, rebuilt enough engines, and changed out enough clutches to know what break wear indicators sound like, and to know they dont sound like rubbery honks coming from the center of the car, just as loud on the inside as the outside.
    Some here must have experienced this before. Whats going on, and should I be worried, and why do the breaks have power when the car is turned off and there is no vacuum???
  2. Patrick Wong
    18,200
    6,493
    Recall that the Prius gasoline engine turns off frequently in normal use. Hence it would not be useful for the braking system to depend upon engine vacuum. Instead the Prius has a brake pressure accumulator pump which is electrically powered.
    TSB BR001-07 is relevant to your complaint and you need not worry since this sound is not indicative of a safety issue. I also have recently started to notice this sound on my 2004 with 86K miles, especially when the car is at high altitudes.
  3. DirkG
    DirkG Junior Member
    Eugene, OR
    What was I thinking. Of course there is no vacuum when the motor is off. My 2007 has almost 70k on it. Thanks for the help.
