Hood latch . . .
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by tgpii, Jan 29, 2020.
Tags:
  1. tgpii
    tgpii Member
    382
    63
    Tapier Lake/Orland Park, Ilinois
    I have a 2012 Toyota Prius C. The hood latch is worn out. I need to replace it. How hard is it to replace it? how much should a new one cost? Online I see low as $20.00 and high as $120.00.
  2. Priuslover09
    Priuslover09 Member
    365
    48
    Dc
    Why do you need to replace it?
    49,500
    it's worn out
  4. tgpii
    tgpii Member
    382
    63
    Why is it fixable? Why do you replace most car parts? Either they are broke or to modify the car.
  5. PriusCamper
    PriusCamper Senior Member
    11,105
    4,519
    Pacific Northwest, USA
    Best things to do is find a wrecking yard that has a Prius C and remove the hood latch from the wrecked car yourself so you will know how to replace it on your own car. This will also ensure the part cost less than $20. This is a very easy nuts and bolts project that will take less than a 1/2 hour if you have all the tools you need.
  6. tgpii
    tgpii Member
    382
    63
    I seen new latches for $20.00 online. Is the latch going out common?
  7. tgpii
    tgpii Member
    382
    63
  8. bisco
    49,500
    no, it is virtually unheard of. are you sure you have made a proper diagnosis?
    John in Vermont likes this.
  9. Mendel Leisk
    38,730
  10. tgpii
    tgpii Member
    382
    63
    So I put a ton of oil, WD40, and grease on the hood latch assembly. Seems to be working. Thanks.
  11. bisco
    49,500
    well done!(y)
