Horn replacement
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Devilsbard, Jan 21, 2016.
  1. Devilsbard
    Devilsbard New Member
    i love my Prius but the horn is laughable. I'm wondering if replacing it would affect my warranty. I'm thinking about something like this...
  2. Munpot42
    Munpot42 Senior Member
    1,391
    543
    Santa Monica, Ca. 90405
    There should be links about this on the site, many have changed or enhanced their horn.
  3. xliderider
    xliderider Senior Member
    7,869
    3,116
    Honolulu, HI
    It's likely possible, if you can find the space to mount everything. There is a good amount of space just below the driver's headlight, in front of the wheel well. You can mount the compressor there.
    If the compressor pulls more amps than the stock horns, you should use a relay, and pull power directly from the fuse box auxiliary terminals in the back.
  4. xliderider
    7,869
    3,116
    Honolulu, HI
    Also, regarding it affecting your warranty. It won't, unless you totally botch the installation, and even then, Toyota has to prove that it caused a warranted part to fail before denying a warranty claim.
  5. xliderider
    7,869
    3,116
    Honolulu, HI
    Have you read through the long aftermarket horn thread on this forum (link in my signature below). Several members have installed wolo airhorns, and stebel nautilus horns.
  6. mrbigh
    3,686
    699
    Long Island, NY
    I installed an small train air horn in my former PiP. It was laud and unexpected:censored:....
  7. andino
    andino Senior Member
    746
    550
    San Jose, CA
    The airhorns in the OP aren't too great. I had them for a while and the only way to mount them is with the horns pointing down in the stock location. They weren't very loud though so I'd actually recommend going with HELLA horns or something. They're louder and will fit with the stock location.
  8. 12n14V
    12n14V New Member
    SD CA
    Is the difference between Hella and Fiamm that the later has the same terminal so no cutting is required? It appears the Hella requires a differant connector. Aw "Hell" !
  9. WilDavis
    WilDavis Senior Member
    2,492
    2,153
    49
