Horn Stopped Working
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Jesse Melara, Jul 15, 2014.
  1. Jesse Melara
    Jesse Melara Junior Member
    39
    Los Angeles
    Hello all!
    I have a question and hopefully you guys or gals can help me...I have 2010 Prius, package 2. My horn stopped working a few months ago. I never got around to seeing whats wrong with it. I am not sure if it is the fuse or what ever. Can someone tell me where the fuse box is? Or what it can be? I did have a back up camera installed shortly before it went out...someone please help. Try to explain like I am 5 years old haha.
  2. Jerri
    Jerri New Member
    Stanwood, WA
    My horn stopped working about 2 months ago in my 2010 Prius. I stopped O'Reilly ' s Auto and the guy showed me where the fuse was but it 2 as good. If it needed to be replaced he said it has to come from Toyota because it is a Jumbo fuse that has three in one. So the problem is either in the horn itself located in front of the radiator or in the steering wheel where the airbag is at. My horn works when the alarm goes off so I am guessing it is in the steering wheel. Am wondering if the air bag recall has anything to do with it but they say my car is not one of them. :$(
  3. Jesse Melara
    39
    Los Angeles
    I found out what it was about 4 months ago by testing my panic button. Horn went off. Then one day when I turned my wheel and pressed the horn it worked. It turned out it was the spiral cable. It seems to be a common issue with Toyota. They just refuse to acknowledge the prius as one of the cars effected. Luckly I am good friends with the service manager at a Toyota and he got it fixed for free. Now it works.
    So most likely it is the spiral cable for you as well.
    Tater25 and ou812 like this.
  4. blaze001
    blaze001 New Member
    I'm facing similar issue and trying to troubleshoot. Did the other buttons on your steering wheel work? For me, it's just the horn that doesn't work when pressed.
  5. bighouse
    bighouse Active Member
    822
    126
    Guerneville, CA
    Very interested in this thread, just realized my horn hasn’t been working.
  6. bisco
    52,371
    me too. my horn works, but you never know
  7. ChapmanF
    18,529
    If you hold the horn pad in the pressed position and turn the wheel around to different positions, does the horn beep in some places and not others?
    If so, that's a smoking gun for the spiral cable behind the wheel.
    If not, then you haven't found a smoking gun; could still be the spiral cable, or be something else.
    Tater25 and Mendel Leisk like this.
  8. bighouse
    822
    126
    Guerneville, CA
    OK, I've done some investigating with the horn. My PANIC button on my fob kicks on the horn- so I know the horn itself isn't the problem. I've tried honking the horn with the wheel turned in various positions, both for left and right turns, minor and major turns, but that doesn't seem to be it either. I did, after driving around for a while and constantly trying to honk my horn by pushing on it at various locations on the face of the airbag, find ONE spot that if I press on it, sounds the horn. It's an area that's in the left, bottom section of the airbag area and I can reliably get it to honk if, and only if, I press it in this one location on the pad.
    So, what does this indicate? Is it this "spiral cable" or do I have some kind of dirt/dust/debris that's causing the other switches that must exist between the pad and the wheel, that are in need of cleaning or replacing?
  9. ChapmanF
    18,529
    Exactly the kind of thing I'd look for. If I remember right, the horn contacts are open and exposed behind there. A set of them might be kind of oxidized or dirty, or there might even be something in the way back there, like a wire that happened to fold the wrong way when the pad was last installed.
    Should be pretty simple to find, but will mean taking the airbag out. Be sure to bone up on all the safety rules for that.
  10. bighouse
    822
    126
    Guerneville, CA
    I found this excellent video on YouTube.
    Russell Lane likes this.
  11. ChapmanF
    18,529
    It's not bad. For your own purposes, you're not likely to need any more of it than the part for getting the airbag off.
    The 12 volt battery is disconnected as soon as either terminal is. No need to do both. No need to fuss with the orange traction battery plug at all. You're not going to be doing any high-voltage system work here. A quicker way to disconnect the 12 volt battery is just to unplug the fat white cable in the underhood fuse box. (In my car, that would leave some of my added toys still powered that are connected right back at the battery. But it depowers all the stuff that came with the car, which is what matters here.)
    The more willing you are to work on those plastic cover panels without metal picks and such, the fewer unsightly gouges and scratches they'll have when you're done.
    Once he has the airbag out, he puts it out of the way in the back seat, off camera. That makes this a good place for an open-book safety quiz: whenever you set down an airbag, you set it down which way up?
    Once you've done that, you should have no problem seeing what's up with the horn contacts. The horn beeps when that blue wire attached to the airbag gets grounded (to the metal frame of the steering wheel itself, mounted solidly on the steering shaft). The structure that the airbag pops into is normally insulated from the grounded parts, except when you are pushing on it, and you should be able to find the contacts that touch when you do that.
    Only for future readers who would want to follow that video further, say to replace the spiral cable:
    Mating marks are good for the wheel and the steering shaft. A mating mark on the nut won't necessarily tell you when it's properly retightened; a torque wrench is better. Toyota does not specify Loctite for the nut, as long as it's correctly torqued.
    Avoid pulling a lock pin from a new spiral cable before the spiral cable is installed on the properly-centered steering shaft with the wheels straight ahead. If you're transferring over the steering angle sensor from an old cable like the guy in the video, and you have his problem with the sensor tabs not lining up with the spiral cable notches, don't forget the sensor also can be turned. ;) (You don't run into that problem if you buy a Toyota spiral cable, which comes with the sensor already.)
  12. renyj
    renyj New Member
    houston
    my car beeps when turn the wheel while in pressed position.
    smoking gun issue? do I need to replace this part or spiral cable whole part?
    Thanks
    #12 renyj, Aug 17, 2022
  13. ChapmanF
    18,529
    If the car beeps, intermittently, as you turn the wheel, while holding the horn pad steadily pressed, then yes, that is a smoking gun for the spiral cable.
  14. johnhuff
    johnhuff Junior Member
    35
    Los Angeles
    I just swapped out my steering wheel controls. They didn’t work properly so I put the original back on.
    now my horn and original steering wheel controls are both nonfunctional.
    when I turn the steering wheel, there’s a plastic crackling noise. I’ve found the the noise comes from the spiral cable box behind the steering wheel.
    what’s going on and how much will I spend to fix it?
  15. ChapmanF
    18,529
    If the spiral cable is damaged, the only official repair is another spiral cable. A Toyota one may be a couple hundred. Maybe more; in Gen 3 they started bundling it with the steering angle sensor and charging more like half a thou.
    There are cheap ones in the aftermarket, but that's because they're cheap.
  16. gregsparrow
    gregsparrow New Member
    Ukraine
    Can you please advice one of these cheap one? Is it worth it to use? Thanks in advance.
    Had the same issue on my Lexus CT200h. It honks if steering wheel meets certain position ....
  17. mr_guy_mann
    mr_guy_mann Senior Member
    4,087
    1,997
    NJ-USA
    {shrug}
    I have seen aftermarket "clockspring" assemblies last 4 years, & I've seen them only last 9 months.
    The original Toyota part went over 10 years(?). The one in my 2006 is still ok (knock on wood).
    Do your own research. See what the prices are. Make your own decision.
    FWITW, I just get most all parts for mine from the Toyota dealer.
