Horn when locking doors
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Rodney O, Dec 4, 2014.
  1. Rodney O
    Rodney O Junior Member
    27
    Parsons, KS
    I am used to hitting my lock button on my key fob and hearing the horn honk to confirm it is locked. Is there a way to have the horn blow as well as see the lights bling to indicate the doors are locked?
    Thanks,
    Rod
  2. Easy Rider 2
    Easy Rider 2 Senior Member
    1,584
    258
    Ocala, FL
    This may vary a bit by specific Prius model and year.
    Have you looked in your owner's manual yet ?
    There might be an option you can change......but I doubt it.
  3. xpcman
    xpcman Senior Member
    1,302
    295
    California - SF Bay area
    God I hope not. Everyone in the neighborhood has to hear that beep!
    Yakoma and kenoarto like this.
  4. ursle
    ursle Gas miser
    1,049
    192
    NH
    The beauty of the 07 is the button on the drivers handle that you press to lock the car, the key fob stays in your pocket, no the prii don't honk when you lock them, but if you listen you can hear the doors lock.
  5. Rodney O
    27
    Parsons, KS
    Thanks for your reply and now I know it doesn't honk upon locking with the key fob.
    Thanks for your reply. I have searched in the owners manual and it doesn't indicate that the horn will sound in any way when locking the doors. Someone told me it will beep when locking but I don't hear that either. I really like this car......it is our first Prius and we are hooked!
  6. bisco
    51,141
    the beep is pretty quiet, especially with ambient noise, and for those of us who are a bit hard of hearing. what?
    #6 bisco, Dec 17, 2014
  7. Aaron Vitolins
    Aaron Vitolins Senior Member
    1,612
    1,144
    Franklin TN
    I'm pretty sure almost all toyota models have the same beeping sound when locked. I do believe I've read here on PC that someone either disabled or enabled the beep. Not sure, but when you're in a parking lot I hear the same toyota beeping sounds alllll the time
    kenoarto likes this.
  8. Easy Rider 2
    1,584
    258
    Ocala, FL
    That "someone" guy is good at passing out bad information, it seems. ;)
    Mine chirps/beeps when you lock it regardless of the method but it is 6 model years newer and a different model too.
    kenoarto and Aaron Vitolins like this.
  9. Rodney O
    27
    Parsons, KS
    I have a 2007 Prius with most of the extras. How do I activate the beep sound to happen when I lock the car to confirm it is locked. I am used to my Ford F-150 horn honking but cannot get my Prius to make any sounds.
    Anyone know how to turn this feature on without having to pay the dealer to program it?
    Thanks,
    Rod
  10. kenoarto
    kenoarto Senior Member
    398
    Chicago, IL
    Our 05 beeps and flashes lights
  11. Yakoma
    Yakoma Active Member
    470
    125
    sss
    Who?
  12. GregP507
    GregP507 Senior Member
    3,002
    481
    Someone will know how to shut it off.
  13. bisco
    51,141
    you need an obd II tool such as scan gauge. or you can shop around, some dealers will do it out of the kindness of their heart.
  14. Rodney O
    27
    Parsons, KS
    Thanks so much and can you please tell me what an obdII tool is?
  15. WilDavis
    WilDavis Senior Member
    2,493
    2,154
    49
    …from the owner's destruction manual for my 2009 Gen II, check section 1-3, page 43. It talks about a beep, but says nothing about the horn, perhaps you might ask your neighbours' opinions on having the horn warning every time you lock/unlock your car…;)
  16. bisco
    51,141
    an obd II tool, is an electronic device that connects to the computer port of the car. they use it to diagnose, check emissions and etcetera. scan gauge is one brand, there are others. you can get one here at the priuschat shoppe, or google it and amazon will provide.
  17. PriusGuy32
    1,417
    513
    Harrison Township, Michigan
    I have Techstream and have never seen an option to make the horn blow when you lock the car, and Ive been deep in the "utility" portion of every subcategory many times....
    HOWEVER, why not go to a car alarm store and have an aftermarket keyless entry installed? Those always blow the horn and flash the parking lights when you lock the doors, in my experience.
  18. Rodney O
    27
    Parsons, KS
    Thanks so much to you and everyone else for your information. I am going to get the beep turned back on for when I use the lock button. I am a first time Prius owner and simply love this car. My wife and I are hooked and Prius is going to be our only car from this point forward!
  19. goodMXguy
    goodMXguy Junior Member
    44
    Philadelphia
    Were you able to make it happen? If so, how?
