Horrid Gas Mileage?
Discussion in 'Newbie Forum' started by Everett Stamm, Feb 4, 2017.
  1. Everett Stamm
    Everett Stamm New Member
    Columbus, Ohio
    2007 Prius (IDK what generation that is)
    So I know there is a lot of Gas milage questions out there, but I've read aren't this severe. I was getting about 28-30 mpg last week, which isn't good, but considering it is cold outside, I assumed that it was normal. I got my oil changed by a normal chain place, and they did their typical inspection and they didn't find anything wrong. Now I am getting 18-19 mpg, which is far far far below anything I have read about. What should I look into to fix this?
  2. Aaron Vitolins
    Aaron Vitolins Senior Member
    1,612
    1,144
    Franklin TN
    18-19 is far too low. I'd reset the average mpg, fill tires to 40 psi and check the oil. Drive it on the highway and some city. See what it says. Best of luck! Feel free to ask me any questions
  3. Elbrad
    Elbrad Junior Member
    53
    24
    Nanaimo, BC
    Make sure they used 0w-20 as well. Make doubly sure. Apparently some shops can get a little shady and sub cheaper, semi-synthetic oil while charging you the same rate for full synthetic.
    RCO, pleasedpriusowner and bisco like this.
  4. Everett Stamm
    Columbus, Ohio
    Check the oil even though I just got it changed? What should I look for? Also the tires are already filled.
  5. Elbrad
    53
    24
    Nanaimo, BC
    It's going to be hard to tell if they used 0w20 or not just by eyeballing it. I'm really not sure how you'd tell for sure, other than taking it to a shop you trust.
    RCO likes this.
  6. Munpot42
    Munpot42 Senior Member
    1,391
    544
    Santa Monica, Ca. 90405
    You have a Gen 2 model, the factory suggests 5w-30 weight oil, not 0-20, and unless they overfilled the oil (Check your dipstick) oil should not be your problem, a failing 12 volt battery or a failing hybrid battery are among the usual suspects.
  7. Elbrad
    53
    24
    Nanaimo, BC
    Thanks for correcting me. I didn't even look to see what Gen he was.
  8. Munpot42
    1,391
    544
    I forgot one thing you have rubber bladder in your gas tank, so in winter the size of your gas tank varies, it will take a few fillips to determine your gas mileage.
    RCO likes this.
  9. bisco
    52,574
    welcome! how many miles on her? when you own a 10 year old car, it's important to know how to check the oil level and the tyres pressure.
    and with a prius, a knowledge of the 12 volt is also helpful.
    i would check/clean/replace the engine air filter.
    and don't rely on chain oil places for anything
    all the best!(y)
    RCO and pleasedpriusowner like this.
  10. Everett Stamm
    Columbus, Ohio
    I have about 68K miles on her. Where could I read up on the 12V?
  11. Aaron Vitolins
    1,612
    1,144
    Franklin TN
    Sometimes old change places overfill the oil. That's why I would check. Still something is very wrong. What type of driving do you do? Also do you ever watch the behavior of the Hybrid Battery?
    RCO likes this.
  12. jerrymildred
    jerrymildred Senior Member
    11,517
    14,164
    Tampa, FL
    I thought I read somewhere that there was an addendum to the owners manual changing the recommended Gen 2 oil viscosity to 0W-20 but the electronic version I downloaded from Toyota still says 5W-30.
    That said, I don't think 5W-30 would make that much difference. I wonder if they overfilled it (many shops do and that's one of several reasons I change my own). And maybe they did put in the wrong oil AND overfilled it. This sounds like it could be a combination of oil, low tires, dirt cabin air filter, and/or other things piling up.
    RCO likes this.
  13. bisco
    52,574
    this is how i check my 12v health. there are many methods, and threads here with descriptions.
    1) it's a good idea to know how old it is. if you don't know the service history, there is a date code on top.
    2) buy a digital multi meter. $10. -$20. on amazon and useful for many things.
    3) pop the hood at the end of the day, when you're done driving.
    4) in the morning, without opening any doors, open the hood and find the jump point described in the manual.
    5) measure the voltage. 12.4 or better is acceptable. any lower, and it's time to start thinking about a replacement.
    6) an auto parts store can do a load test on the battery. if you're having issues, a voltage check may not be enough.
    because it is in the hatch, the prius battery is small, and doesn't take kindly to being drained.
    it is only used to boot the computers and close relays. if it is weak, the computers get fussy and can display a lot of error messages.
    a bad battery can also drain the hybrid battery trying to keep it charged. in turn, the engine must run more to charge the hybrid battery, reducing mpg's. that's why it's important to keep an eye on it.
  14. Superior Monkey
    Superior Monkey New Member
    Singapore
    How many miles did you drive to get this number? And what was the average length of your trips? Short trips can produce really bad numbers due to the fuel being consumed for initial climate control instead of movement. If your trips are under 10 miles, and especially if they're under five, this could be a major issue. That said, compare apples to apples. If the same trip, in about the same time and temperature conditions, sees a major drop, then something's wrong. But a 3 mile trip in the winter is going to be bad, no getting around that. Other than turning the heater off.
    RCO likes this.
  15. pleasedpriusowner
    pleasedpriusowner Junior Member
    17
    Toledo, Ohio
    It wouldn't surprise me if the Qwicki Oil place didn't put the correct weight oil in AND/OR use synthetic oil. Go bak to QO and insist they VERIFY they put in the correct stuff. All the other suggestions about overfilling the oil, tire pressures, 12V battery, and etc. are good things to check as well. If the 12V battery is the original (check top/side of batt for a date sticker/tag), it is very likely it needs changed. Please let us know what happens. Best wishes!
  16. heyphillip
    heyphillip Member
    131
    47
    Maple Shade NJ
    I get about 37 to 40.3 miles per gallon on short trips like 11 miles.Two weeks ago I took a 47 mile one way trip stop and go traffic and produced 53 miles per gallon . I have a 2010 Prius 4 so it looks like these cars produce better gas milage on longer trips
  17. Prodigyplace
    12,699
    11,842
    Central Virginia
    I think cold weather ICE warmup is affecting your short trip mileage.
    RCO likes this.
  18. Prodigyplace
    12,699
    11,842
    Central Virginia
    How would I do number 4? On my car the hood release is inside the car.
  19. jerrymildred
    11,517
    14,164
    Tampa, FL
    Do number three first. ;)
    bisco, RCO and Sooner Al like this.
  20. Prodigyplace
    12,699
    11,842
    Central Virginia
    Oops!
    I missed that. I wondered about that but figured there was a more secure way. :( :cry:
    Thanks.
    bisco and RCO like this.
