"Hot Coolant Tank Install"?
Discussion in 'Gen 2 Prius Technical Discussion' started by salguod, Oct 21, 2013.
  1. salguod
    salguod Member
    234
    37
    Columbus, OH
    In the service records at the Toyota Owner's site for my new to me 2007 Touring is the following entry from January of this year at 108K:
    The only part listed was 00272SLLC2, Super Long Life Coolant, I assume a gallon. Anyone know what this is?
    I want to figure out if the engine and inverter coolant was changed, as specified, at 100K. On this same work order the HV Electric Water Pump recall was done, so the pump & inverter coolant were changed. I just don't understand the entry above to know if that means the engine coolant was changed too.
  2. Patrick Wong
    18,200
    6,472
    "Hot Coolant Tank" probably means the engine coolant heat recovery system canister, which is located in the left front fender in front of the tire. Typically this canister would require replacement only if the car was in an accident impacting the left front fender.
    The engine coolant was replaced if the coolant heat recovery system canister was replaced.
  3. salguod
    salguod Member
    234
    37
    Columbus, OH
    That makes sense, but there was no listing for the P/N for the tank. Also, why is the ac listed and the back seat? I'm going to call the dealer and ask about it.
  4. Patrick Wong
    18,200
    6,472
    Perhaps this means that the customer provided the air conditioning refrigerant to be used in recharging the system, which had been placed on the back seat. Certainly there are no air conditioning components back there.
  5. salguod
    salguod Member
    234
    37
    Columbus, OH
    I was thinking along the same lines. After getting it home, I noticed the gap along eh sides of the hood is slightly larger on the driver's side than the passenger. I'm wondering if perhaps it was in a minor accident that damaged the hot tank in the LF. Perhaps the prior owner repaired it himself, and acquired a used tank and delivered it to the dealer for installation.
    I haven't called the dealer yet to see if they recall.
