Hot dash
Discussion in 'Newbie Forum' started by johnzonie, May 31, 2009.
  1. johnzonie
    johnzonie New Member
    AZ
    We got our 2009 pkg 6 dark grey around 6 weeks ago and are absolutely loving it. Went from a leased Infiniti M35 and the Prius has more back seat leg room!
    The only problem is the AZ sun. All windows are tinted but the heat streaming in the windshield is almost totally absorbed by the dark grey dash. I've tried searching the forums for some kind of solution without success.
    Anyone know of a light grey dash cover/replacement? I think it might help reflect some of the heat back out.
    Thanks.
  2. F8L
    19,011
    4,081
    50
    Grass Valley, CA.
  3. Paradox
    29,110
    8,589
    201
    2014 Prius v wagon
    In the shop on here they have a heat shield for the front window:
    PriusChat Shop : Toyota Prius HeatShield Sunshade - Front - $30.00
    And front side, rear side and rear window heat shields as well:
    PriusChat Shop : Toyota Prius HeatShield Sunshade - Front Side Windows - $30.00
    PriusChat Shop : Toyota Prius HeatShield Sunshade - Rear - $30.00
    PriusChat Shop : Toyota Prius HeatShield Sunshade - Rear Side Windows - $30.00
    I just don't know if I would have the patience to always install them lol
    edit: Opps, question answered while making this post
  4. johnzonie
    AZ
    Thanks guys - I already have a sun shield. I am talking about when driving :)
    The sun beats down on the dark grey to make it "ouch hot". The A/C is almost always on recirculate trying to keep up with the 100F outdoor temp. My thought is that I could minimize the solar absorption with a lighter color.
  5. Paradox
    29,110
    8,589
    201
    2014 Prius v wagon
    I haven't seen anything that I can think off hand but maybe just tossing a white towel or two on the dash can help a bit when needed as a quick temporary fix...
  6. F8L
    19,011
    4,081
    50
    Grass Valley, CA.
    Did you look into a Dashmat yet? I'm sure you could get one in a lighter color that would help increase albedo. :)
    Here is one brand
    I will not vouch for them as I've never bought one but a quick Google search for Dashmat should bring up more options.
  7. EZW1
    EZW1 Active Member
    722
    Phoenix, AZ
    2016 Prius v wagon
    Four Touring
    There's a local company in Tempe called Dash Mat that makes custom covers for hundreds of cars. My guess is they have one for the Pri.
  8. DocX
    DocX New Member
    Portland Ore
    I have the same problem recently and was thinking of covering the dash (black) with kitchen aluminum foil, seriously, and tape the edges. Any comments?
  9. Paradox
    29,110
    8,589
    201
    2014 Prius v wagon
    This guy where I work was looking for one for his Intrepid several years back and dashmat was the one I ordered for him. It fit perfectly and was nice quality... Kind of like wall to wall carpeting for your dashboard lol
  10. patsparks
    10,664
    567
    Adelaide South Australia
    I had a carpet dash mat in my Camry, it seems to reduce radiant heat from the dash. I can't find one for the Prius although I have seen one on a Prius.
  11. richard schumacher
    7,663
    1,038
    United States
    The Sun reflections would blind you at inconvenient times.
  12. F8L
    19,011
    4,081
    50
    Grass Valley, CA.
    Agreed. Even if you used the non-shiny side and it didn't blind you I have a feeling if you ever got into an accident they would try to use that as a way to pin the blame on you... :(
  13. EZW1
    EZW1 Active Member
    722
    Phoenix, AZ
    2016 Prius v wagon
    Four Touring
  14. Doc Willie
    1,717
    142
    Out there, somewhere
    Yah. You will have the aluminum foil reflecting the sun straight into your eyes. Even with sunglasses, driving will be hazardous.
  15. johnzonie
    AZ
    I contacted Dash Topper in Tempe, AZ. While they assured me the 2008 and 2009 Prius dash covers were the same (not surprising), they couldn't tell me if the dash cover was a full or partial cover and had no way to find out. Very bizarre company!
