hot temps
Discussion in 'Gen 3 Prius Technical Discussion' started by tommyandbeth, Jun 13, 2011.
  1. tommyandbeth
    tommyandbeth Junior Member
    28
    Arbutus,MD
    Fuel mileage dropped from 52 to 40 on several hot days and I heard a constant loud hum.In the shop tomorrow.
    Any ideas?
  2. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,338
    Wilmington, NC
    I would guess that in this hot weather you have been using the AC. The combination of the hot weather and running the AC, especially on short trips, have a big impact on mpg.
    If you are running the AC this is probably the humming that you are hearing. The AC compressor is variable speed and controlled by the Inverter module. The humming that you hear is the switching frequencies of the power components in the Inverter and compressor motor.
    To check the AC, turn it off and see if the humming goes away.
  3. tommyandbeth
    28
    Arbutus,MD
    Regular highway driving as usual so nothing changed on my end except the temps.Battery gauge was low also most of the hot days.This was a first.
  4. jdcollins5
    5,131
    1,338
    Wilmington, NC
    Yes, regular highway driving with AC should not impact mpg that much. Also, if the HV battery is showing low while highway driving this is definitely an issue.
    My HV battery will show low during in town driving while stopping at stop lights, etc. when the ICE shuts off with the AC on. But once I get moving again the battery charges right back up.
    Let us know what the dealer says.
  5. David Beale
    David Beale Senior Member
    5,963
    1,983
    Edmonton Alberta
    The dealer will say "that is normal operation". ;)
  6. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
    Yep on all of the above. Open up the the windows to hear the compressor turn on/off when you turn the AC on/off.
    On the 2nd gen, the AC compressor can get quite loud if you're outside.
  7. bisco
    49,693
    no way does my mileage drop from 52 to 40 with the a/c on. especially on the highway. i get 50-55 all day long on reasonably flat highways at 65 mph.
  8. tommyandbeth
    28
    Arbutus,MD
    The dealer checked the car and of course it was 70 degrees out and all was again ok.It never acts up when in the shop. lets see what happens when it gets hot again.
    Thanks for the replies.
  9. austingreen
    austingreen Senior Member
    13,591
    4,132
    Austin, TX, USA
    How hot and what is the length of your trip. I do get big drops here. If its hot and the battery is low at the start it takes extra energy to recharge the battery. If I'm only going a few miles on the highway I'll get in the 20s. Then the next trip it will pop up. Uphill12 mile trip to the lake saturday in triple digits gave me 38mpg. I don't know if there is something different on the guys like bisco that can get 50 in the heat, but I imagine its the route, but hey my car may have something wrong too:D I average around 42 last summer.
    I doubt the dealer will find anything even if its hot, but good luck. Did you have the car last summer? Did it act differently?
  10. adamace1
    adamace1 Senior Member
    1,403
    191
    Charlotte, NC
    If your going down the highway and your battery is getting low i would let someone ride with you and record that. if your going 55mph the hv battery should stay almost full.
  11. phoenixgreg
    phoenixgreg Senior member
    1,157
    289
    66
    Phoenix
    +1 to austingreen. Try doing short trips in 110 degrees. Even with careful driving habits, my avg mpg (city surface streets) goes from 50 to 42. Granted, if I can get some freeway miles in, it will help bring it up again.
    I've also noticed the SOC get down to 2 or 3 bars on a regular basis in this heat. The compressor really sucks the power.
  12. tommyandbeth
    28
    Arbutus,MD
    Flat roads no hills when all this happened.20 miles of cruising.
  13. austingreen
    13,591
    4,132
    Austin, TX, USA
    Your mileage does seem out of line then. On longer trips when I'm not in a traffic jam, the battery does charge up and mpg does rise.
    I do think there is likely something wrong with your car. I am not that good with remote diagnosis though. I would try running in eco to see if its the ac drain, but there may be a problem with one of the batteries or sensors. Electrical problems are tough to figure out. Hopefully someone more versed can help.
  14. richard schumacher
    7,663
    1,040
    United States
    If the hum is coming from the *back* seat then it may be the traction battery cooling fan, and the traction battery system may be unhappy.
  15. andyprius
    andyprius Senior Member
    2,212
    188
    Sacramento, California.
    Try force charging the HV in two modes. 1. Without AC 2. With AC. In both cases you should reach the 2/3 charge point. W/O the AC on, you should reach the green bars, not necessarily total green. If the car can do that it's OK. If not there may be a problem. use the 72-78 F temp range.
  16. bigmike5
    bigmike5 New Member
    25
    San Jose, CA
    What temperature is your A/C set to?
  17. new2hybrid
    new2hybrid New Member
    35
    Delmarva
    Went on a trip, mostly highway with A/C on. Got 60 mpg!
    I do notice around town with short trips I average around 40 though. It's been humid and around 90 -- have major humming. Scared me at first but realized it happens just when A/C is cranking, mainly when I first turn it on and the car is hot (park outside).
  18. mmcdonal
    mmcdonal Active Member
    666
    98
    16
    Columbia MD
    I was going to observe the same fact, especially if there is anything on the back seat that is blocking the intake duct.
  19. andyprius
    2,212
    188
    Hopefully there is NEVER anything blocking that duct! The owners manual points this out.:D
  20. tommyandbeth
    28
    Arbutus,MD
    No the duct is wide open but the fan was so loud I thought the back door was not closed properly.All seems to be normal at the moment.I thank all of you for the replies.
