Hot Water Heater Timers
Discussion in 'Environmental Discussion' started by JSH, Feb 12, 2009.
  1. JSH
    JSH Senior Member
    2,605
    140
    PDX
    Has anyone installed a timer for their hot water heater? I'm looking to cut down on energy use and have thought of trying a timer. We use very little hot water already, really only for showering so it seems pointless to keep water at 120F 24/7. I was planning on setting the timer to be hot from 5 PM to 9 PM Mon-Fri and 8 AM to 9 PM on Sat/Sun. Any idea on how much energy this would save?
    Some background if you are interested:
    The recent tax credits for energy efficiency got me looking into what I can do to reduce electricity use. I looked into tankless hot water heaters but the electric models don't save a significant amount of energy and don't qualify for credits. When I got back home I looked at my hot water heater. It is a 50 gallon tank that according to the energy star sticker uses 4823 kWh's per year! I have an all electric house and my total energy use was 8000 kWh for 2008. I doubt the hot water heater uses almost 5000 kWh's but I would guess it is at least 3000 kWh's.
  2. efusco
    efusco Moderator Emeritus
    19,891
    1,191
    Nixa, MO
    While a timer might help a little bit, I suspect that the inconvenience of not having hot water when you want it occasionally and the additional energy required to heat up cold water will make this a less than ideal solution.
    I'd suggest a more radical solution...either a tankless water heater or a solar water heating system.
  3. krousdb
    krousdb NX-74205
    580
    498
    47
    Raleigh, NC
    The energy saved would be equivalent to the amount of heat lost through convection and that only applies to the time the water heater is shut off. My guess is that you would be better off installing a water heater blanket to increase the insulation value. A blanket would help you save 100% of the time, not just when the heater is off. If you already have a blanket, I doubt that you will notice a difference.
  4. JSH
    JSH Senior Member
    2,605
    140
    PDX
    A whole-house electric tankless system out of the question. It will cost ~ $600 to save $20 per year in electricity. I don't have natural gas available to my house.
    I would love to install a solar hot water system. However, even a passive system is about $2000 if I do the installation compared to $40 to $60 for a timer. We are not in the position to spend that amount of money right now.
    I'm not seeing the inconvenience factor. I don't wash clothes in hot water. I don't wash dishes with hot water. I don't wash my hands with hot water. I only use hot water to shower once a day and that is done in at night. My wife may complain about washing her face and bushing her teeth with cold water in the morning but I would assume that the water in the tank would still be at least 80F in the morning. If this was an issue I could install a $200 point of use tankless heater under the sink.
  5. EZW1
    EZW1 Active Member
    722
    Phoenix, AZ
    2016 Prius v wagon
    Four Touring
    I've got news for you all. I use one in my house. I noted some electric bills for 3 months before installing the timer and the same 3 months after installing it. Result: The timer lowers my electric bill by an easy $30/mo. I've set the timer to come on at 5AM and off at 9AM, then on again at 6PM and off at 10PM. This is plenty of time to have an abundance of hot water for a shower in the morning, and for cooking and cleaning in the evening. If a laundry day comes, my wife knows to hit the override button which puts the heater on full time until the next off cycle arrives.
  6. Celtic Blue
    Celtic Blue New Member
    2,224
    139
    Midwest
    I doubt it will save much because you are only saving on some heat losses at the tank. If it saved 5% I would be surprised. There was a timer on the water heater in one house we were in, but I never used it.
    The best way to cut tank losses in an existing tank is to insulate the piping to and from the water heater, and to insulate the water heater itself with an R6.7 or R11 blanket. Typically the tank's own insulation is around R8. With an electric you can insulate the top as well (you can't do this with gas since it is to close to the flue.)
    There are also some changes that can be made to the piping adding external traps to prevent a thermosiphon (rising hot water in the pipe being cooled and falling back into the tank.) Newer tanks may have some sort of internal traps to reduce this tendency.
    Use the model # on the heater to pull up its energy guide. From that you can determine its estimated annual energy demand. You should also see its efficiency rating on the nameplate or the guide. For an electric almost all the efficiency loss will be tank/piping heat loss. That's the portion you can do something about with insulation, timers, traps, tankless systems, etc. (other than cutting actual use.) With a gas water heater you lose an extra ~15% up the flue unless it is a condensing unit (rare.)
  7. Celtic Blue
    2,224
    139
    Midwest
    For me that would be 300 kWh. That's more than I use in hot water in a month. Doesn't compute unless your electricity is around $0.50-1.00/kWh. The tank losses should not be that high.
  8. tripp
    tripp Which it's a 'ybrid, ain't it?
    4,717
    79
    Denver, CO
    Well, if nothing else could you downsize to a 40 gal? That coupled with a blanket, low-flow showerhead, and time should put a dent in your energy use. Since you're all electric, you might seriously look at solar thermal. I think if you're on electric heat you'll get a pretty good bang for the buck (much better than gas water heating for a couple of reasons). There's a 30% fed tax credit for solar thermal installs so that could make it attractive to you. The idea situation would be solar thermal with tankless backup. I'm surprised that the electric tankless models don't have a significant savings over a traditional.
  9. darelldd
    6,057
    388
    Northern CA
    I use a timer. I also shut off the heater before I take my shower. When I'm done, the water in the tank sits at a lower temp, and thus cools slower. I then heat it up before my next shower. One bit of advice: Have everybody take showers back-to-back so the water in the pipes doesn't cool down between. Be sure the tank is up to temp before the first shower, and turn the heat off just before the last shower. All this combined will definitely save energy.
    One thing to note... especially with a 50 gallon tank - having it off doesn't mean that you'll have "cold water" for washing your face, etc. It just might not be blistering hot. 50 gallons of hot water can (should!) certainly take you through a normal day without the heater on.
    Interestingly enough, I don't have an electric heater, though mine has an electric switch that controls the exhaust fan, and thus the electronic gas start. I can just use a regular lamp timer. And I have a remote on it so I can switch it from upstairs at the shower. I have a pilotless gas heater.
    Running the heater once a day will definitely save energy as opposed to having it tick on several times just to maintain. Now much it saves is debatable - but it WILL save.
  10. JSH
    JSH Senior Member
    2,605
    140
    PDX
    I'm not looking for a huge savings. The DOE's Consumer Guide to Energy Efficiency and Renewable Energy estimates a 7% to 12% reduction. I've also read the less hot water used the greater the savings because the hot water sits in the tank and cools longer. I'm estimating 10% reduction.
    3000 kWh x 0.1 = 300 kWh
    300 kWh x $0.08 = $24 per year or a 2 year payoff.
    More importantly it will offset the increased electric demand from the chest freezer we will be adding to store our veggies this summer.
    I have thought about an insulation blanket for the tank but the DOE says they are need only if the tank is hot and it is not. A blanket is $25. I've also thought about traps but I'm not sure if my tank has them. It is 8 years old. Heat traps are also $25
    I would like to insulate the pipes but I can't. My house is on a concrete slab foundation and the water lines are in the concrete. I have ~ 1 foot of exposed pipe in the garage and the same at each point of use. This is a huge heat sink and it takes at least a minute to get warm water at the tap.
  11. jayman
    jayman Senior Member
    13,439
    639
    Winnipeg Manitoba
    When both my parents were still alive, they lived the last 10 years of their life in a seniors community, typical side-by-side condos with nat gas heat and electric hot water.
    They got in the habit of using the breaker to turn off the hot water tank when not in use. Even with power as cheap as it is in Manitoba, this saved them $20 a month.
    The circuit breaker went haywire after 9 years of this. So I picked up a brand new $20 two pole 20 amp breaker, took me all of 5 mins to put it in.
    With the nat gas hot water tank, I don't bother turning it off unless I'll be away for awhile and nobody else will be in the house. It's a bit of a PITA to relight the pilot, but I finally got a bbq lighter to take care of that issue.
    The only gas I use in summer is for the hot water tank, and my gas bill is usually $40-$50 a month. Here at least, electric heaters are cheaper to run. I like the gas tank as it recovers much quicker, never run out of hot water
  12. Celtic Blue
    2,224
    139
    Midwest
    Look, you are trying to reduce the same heat loss whether you use a time or insulate the tank. What does using a timer accomplish? It reduces losses by allowing the water in the tank to cool (but you have to heat it back up so some of the savings is lost again.) The average temperature of the tank during the day is less as a result of the timer so losses are less, the question is how much? Now what does insulation do? The same thing, it reduces the average wall temp...but continuously.
    Your tank is likely to be about R8 and have about 1" of foam insulation. No, the water heater wall will not feel hot with only 120 F on the inside. 120 - 70 = 50 F differential. Wall temp will be about 70 + 50 / 8 ~ 76 degrees. Insulate it and it will drop to about 73 degrees...but you will cut the heat loss almost in half.
    Those short runs of pipe near the water heater should be insulated if possible. Copper is a great conductor so that nice insulation already on the tank is being compromised by the pipe. (There are restrictions on this with gas because of flammability issues.)
    For my tank the blanket payback is about 2 years. (I did a semi-rigorous heat transfer calc accounting for the areas I can't insulate as well.)
    I'll take a look at the timer claims, but it seems more logical to spend $25 on the blanket first rather than $40 or more on the timer. "Both" might be the answer you are looking for.
    Current electric water heater energy factors are about 90%. So the max theoretical reduction is about 10% if you were to waste zero heat in storage. Using a timer won't knock it to zero, because the tank will cool while the timer is off and have to be reheated. (darrelldd will come close to that because he is not allowing the water to heat again while in use, so he is using like a modified demand system.)
  13. Syclone
    Syclone Member
    540
  14. Fibb222
    Fibb222 New Member
    1,499
    99
    My electric water heater is less than 2 years old so I haven't bothered with a blanket.
    Should I?
  15. JSH
    JSH Senior Member
    2,605
    140
    PDX
    A normal hot water heater will cycle on and off multiple time per day. The water cools set point amount (say 10F), the heater turns on and heats the water back up to temperature, and then the cooling starts again.
    An insulated blanket slows the rate of cooling so the tank doesn't need to cycle as many times per day. I get that. I also understand that insulation will help even with the timer.
    A timer reduces the heat cycles to one. However, the water cools to a lower temperature so more energy is needed to heat the water (say 50F) in that cycle than a typical cycle if the heater was attempting to keep a constant temp.
    I know that both reduce energy use. The question is which reduces energy use more (which should I do first). That depends on how many times the hot water heater will cycle with the insulated blanket on it.
  16. Massprius
    Massprius New Member
    Boston
    I can't believe you don't wash your hands or your dishes with hot water! That is what kills the germs or the bacteria. Don't be offended when I don't shake your hand or eat at your home anytime soon. I'll just wave from afar and eat take out.
  17. JSH
    JSH Senior Member
    2,605
    140
    PDX
    You can't hold your hands in water hot enough to kill bacteria.
    During hand washing most bacteria are removed by the manual scrubbing action. Warm water does make it easier to remove oils so it can speed up the process.
    I actually wash my hands: Wet, lather, scrub for 20 seconds, then rinse while continuing to scrub vigorously.
  18. efusco
    19,891
    1,191
    Nixa, MO
    It was alluded to but hasn't been outright stated...if you haven't already, you water heater should be set to about 120F. This is safest if there are children in the house, and is adequate for showering and most other hot water needs....and obviously saves some energy.
    Lastly, I realize you have a financial agenda here, and that's laudable. But, IMO, the overriding goal should be energy savings. To that end perhaps it makes most sense to do both a blanket and a timer.
  19. JSH
    JSH Senior Member
    2,605
    140
    PDX
    I already have the water heater set at 120F.
    I was planning on doing both a timer, blanket and heat traps (if my water doesn't have them) within the next couple of months. I may go a different direction though. I was planning on adding insulation to the house this year but may do solar hot water instead.
    • The tax credit for insulation is 10% of material cost up to $500 but it is only good for 2009
    • The tax credit for solar hot water is 30% of material cost up to $2,000 but the credit is available until 2016.
    I'll have to do some more research on solar and look at the budget again. I would think that solar hot water would increase resale on the house and make it stand out from the rest of the neighborhood. I doubt most people would be willing to pay more for added insulation.
  20. icarus
    icarus Senior Member
    4,884
    976
    earth
    Demand water heaters!
    If you have electric, blanket the hell out of it, set a timer to turn on a couple of hours before your major use,, (assuming you don't have time of day metering!) There is no reason after your evening shower, to reheat the water to ~120f have it cool overnight and the next day, cycling on and off doesn't have to happen. A water heater will recover quite quickly. The water in the tank will remain hot enough during the day to wash hands, laundry and dishes.
    Every little bit helps,
    Icarus
