Hot weather and range?
Discussion in 'Prime Fuel Economy & EV Range' started by pawdugan, Jul 5, 2018.
  1. pawdugan
    pawdugan Junior Member
    Charlotte NC
    2018 Prius Prime
    Just curious, but I've noticed my range slipping maybe 5% or so during my commute now that the summer temps are here (been in the mid 90s here).
    I don't run the A/C, so wondering if the heat is having an effect on battery efficiency.
  2. padroo
    padroo Senior Member
    2,763
    2,250
    The A/C doesn't seem to bother the MIPG like the heater does.
    Creature comfort options are meant to be used.
    Starship16 likes this.
  3. john1701a
    john1701a Prius Guru
    12,754
    5,245
    57
    You may be experiencing a negative impact to the battery by not keeping it comfortable.
    Use the A/C to keep both yourself and the battery cooler. Then report back to use if there's an improvement.
    btw, If you had an aftermarket phone-app, like HybridAssistant, you could actually monitor the battery temperature.
    Starship16 and EyePrime like this.
  4. Andyprius1
    Andyprius1 Senior Member
    2,327
    859
    Cool CA
    Since hot weather is here, and I must now park outside and I must charge every day around 1000, after returning home. I wonder if Maybe I should precondition before charging for Bat. longivity.
  5. El Dobro
    El Dobro A Member
    6,978
    3,213
    Do you hear the cooling fans come on when you plug in?
    Andyprius1 likes this.
  6. Andyprius1
    2,327
    859
    Cool CA
    No, I’m hard of hearing. Should they on a hot day while charging?
  7. El Dobro
    El Dobro A Member
    6,978
    3,213
    I would imagine the fans would come on to keep the batteries cool while charging. When I get home from my commute on hot days and I plug the Volt in, after a few minutes, I can hear the A/C compressor come on to cool the batteries.
  8. Starship16
    Starship16 Senior Member
    1,348
    1,453
    Beach Christmas
    Finally, Video of Prime Battery Disassembly
    Discussion in 'Prime Technical Discussion' started by DavidA, Yesterday at 10:55 PM.
    Look for that post by DavidA. Very good videos by John Kelly, Professor at Weber St University.
    He warns how not using the AC can be detrimental to the life of a Prius battery. Also very good videos of the transaxle and regen brake system.
    I don't have a Prime. But I use my AC 90% of the year. Gas mileage is fine. The Professor explains that you are hurting your battery more, than you are saving fuel or increasing efficiency.
    #8 Starship16, Jul 8, 2018
  9. DavidA
    2,328
    1,812
    Chicago western burbs
    Following a full charge in the summer, even though the estimated range might indicate 37 miles, if it is driven in temps of the 90's F, the actual range might be only 2/3rds that, or less, especially if the A/C is used. High battery temps will absolutely reduce the EV mileage. The Prime seems to just love temps of 60-75.
    Mark57 and benagi like this.
  10. Mark57
    2,945
    2,736
    OK
    This was confirmed in real time if any of you watched the special on the Solar Impulse 2 flying around the world. They went into a very good description of the performance and range loss due to battery temps. After watching that show, I ALWAYS allow my A/C to run during charging if it want's it.
  11. Andyprius1
    2,327
    859
    Cool CA
    Good point, the annoying thing is, to quickly hit yes before it disappears. No adj. for that I suppose. The ideal would be to always keep the battery at its healthy temp.
    Mark57 likes this.
  12. bisco
    49,388
    this thread should be a good read for @mr88cetregarding his thread, 'no, it's real: ev range down'.
  13. El Dobro
    El Dobro A Member
    6,978
    3,213
    After a drive down the shore last night, I plugged the Volt in to charge it and even at 82F, the A/C came on to cool the battery.
  14. bisco
    49,388
    i wonder if volt relies more on cooling than battery/control software design, and prime relies more on battery/control software more than cooling? since one is liquid cooled and the other air cooled.
  15. El Dobro
    El Dobro A Member
    6,978
    3,213
    From what I've read, the battery also heats up when discharging, so after my highway run, the system starting cooling the battery for charging. The system is doing what it's designed for, protecting the battery.
  16. padroo
    2,763
    2,250
    I think my new Prius handles the heat better than my Gen 2 did as far as the battery is concerned.
  17. Old Bear
    Old Bear Senior Member
    712
    1,049
    Boston, Massachusetts USA
    When the traction battery is hot, the Prime asks if it's OK to run the A/C while charging.
    See the PriusChat discussion thread here.
    I've seen this pop-up message on several occasions when I have turned off the car, but I've never been fast enough able to respond to it before it disappears. (I think the default setting is Yes.)
    Glenn G and Andyprius1 like this.
  18. DavidA
    2,328
    1,812
    If it is hot outside, or you think the battery temps will cause that screen to appear, just anticipate it and have your finger on the left button. There is about 4 seconds to respond.
    Mark57 and Andyprius1 like this.
  19. Andyprius1
    2,327
    859
    Cool CA
    If the default was Yes, there would be no problem hitting the button fast enough.
