"Hotwiring" SKS
Discussion in 'Gen 2 Prius Main Forum' started by tleonhar, May 3, 2006.
  1. tleonhar
    tleonhar Senior Member
    1,541
    34
    Belle Plaine, MN
    I was just snooping on one of the Gasbuddy sites. Someone has a post about people hacking the signal from SKS fobs to steal cars. Here's the link http://www.leftlanenews.com/2006/05/03/gon...-to-steal-cars/ Anyone heard of this with the Prius???
  2. ScottY
    ScottY New Member
    1,250
    Long Island, NY
    There was a post about this before. A professor at Johns Hopkins University successfully unlocked a TI-RFID equipped car. http://rfidanalysis.org/
    Reason being that the TI-RFID systems uses 40-bit long crypto key. With today’s computing speed, that takes relatively short time to crack the code. The TI-RFID system is used on late model Toyotas, including the Prius I assumed.
  3. plasm
    plasm New Member
    56
    Cambridge, MA
    <div class='quotetop'>QUOTE(ScottY @ May 3 2006, 04:35 PM) [snapback]249251[/snapback]</div>
    Okay, so that means anyone with the right hardware could steal my car in 20 minutes?? Isn't this a huge problem that Toyota should be addressing?
  4. efusco
    efusco Moderator Emeritus
    19,891
    1,192
    Nixa, MO
    there was also an article in wired last year that said that the security of the SKS was far superior than any other vehicle protection system available.
    Someone would need to be within 15 ft of your fob with the right equipment as the code was passed to steal it. But yea, if your really paranoid and really think this is a big risk then call Toyota.
  5. finally_got_one
    finally_got_one New Member
    151
    Orange County, California
    <div class='quotetop'>QUOTE(efusco @ May 3 2006, 03:16 PM) [snapback]249335[/snapback]</div>
    Yep, it could be done. Theoretically. Practically, though, is another thing. But it started me thinking...
    Dont garage door openers have a 'rolling code' these days so that the code could not be recorded and transmitted? It would seem to me that this would be the way to go with SKS, with a little thought put into the programming of the FOBs. ;)
  6. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    The SKS doesn't pass the same code each time, so even stealing the code with a radio device won't let you steal a Prius. It's much like the rolling code on some garage door openers, but even more sophisticated. You would need to mount a brute force attack using very large amounts of computer power, which takes a large amount of time. If someone wants to steal your Prius, it's going to be much easier to just tow it.
    Tom
