HOUSE GATES MALFUNCTIONING -PRIUS DID IT?
Discussion in 'Gen 2 Prius Technical Discussion' started by Briana Giselle Jauregui, Aug 26, 2017.
  1. Briana Giselle Jauregui
    Briana Giselle Jauregui Junior Member
    South Pasadena, CA
    Hi y'all!
    We've an electronic gate system at the house with 3 PriII(?) on the property and a New Beetle(2002) and I feel like the gate is malfunctioning because of Prius.
    Whenever I'm driving the Beetle and I click to open the gate I can do so with ease from about a block away it seems-no problem. However the Prius is totally not simple. I have to click a gazillion times or hold down excessively and as of late the gate itself is totally not having it- the alarm blaring and everything. Had to hand crank it with a giant Allen wrench. Kinda fun.
    I was wondering if anybody else has this issue or something like it. I have a 2007 -there are 3other 2010 to 2016.
    I realize it sounds bizarre but one day I was outside in the carport OUTSIDE of the vehicles in between the Beetle and the Prius and the gate started opening.
    I thought: somebody must be coming home.
    Nobody came.
    Then it began closing by itself and started doing this stutter-step to and fro.
    I had to verbally check my position.
    No. Not in car.
    No. Hands empty. Clicker-nope
    No. You're not crazy.
    Yup. This just happened.
    Anywho_
    Thanks.
  2. Sam Spade
    Sam Spade Senior Member
    2,036
    1,023
    2017 Prius c
    I feel that your "feelings" in this matter are irrelevant; you need some EVIDENCE. (Quote from Judge Judy !!) :ROFLMAO:
    IF.....you have a different gate remote in your two vehicles, try switching them.
    Data Daedalus likes this.
  3. Data Daedalus
    Data Daedalus Senior Member
    1,022
    1,183
    Wembley, London
    The Force is obviously strong in at least one of those Prii.
    Has any of them gone to the "Dark Side".......or is it the Beetle that's become a bit of a Sith?
    Meditate on the matter, you must. Only then, a solution will you find....
    iPhone ?
  4. Beachbummm
    Beachbummm Senior Member
    1,160
    392
    have you tried wrapping the remote in tin foil to block the RF and microwave signal?
    it works in hats ..
    if that fails park a few hundred yards away run up to the gate pushing the button as it opens run back to the car and speed trough.
    good luck on your mission if you chose to accept it
  5. drysider
    drysider Active Member
    823
    332
    Liberty Lake WA
    I am not trying to be nosy, but how do you know it works in hats?
    ITBland, Beachbummm and Data Daedalus like this.
  6. Sam Spade
    2,036
    1,023
    2017 Prius c
    EVERYBODY knows that lining your hats with aluminum foil prevents aliens from reading your mind. :ROFLMAO:
    Data Daedalus and Beachbummm like this.
  7. Beachbummm
    1,160
    392
  8. Beachbummm
    1,160
    392
    save yourself!
  9. Data Daedalus
    1,022
    1,183
    Wembley, London
    I'm afraid the link says Video not found......
    iPhone ?
  10. Beachbummm
    1,160
    392
    not sure why its playing for me.. it plays on youtube..
  11. Data Daedalus
    1,022
    1,183
    Wembley, London
    Might be because the link you've posted has ID data which is linked directly to you or your browser. It doesn't follow the convention of a normal YouTube link.......
    iPhone ?
  12. Data Daedalus
    1,022
    1,183
    Wembley, London
    For example, I've attached a conventional YouTube link below:
    Note the convention of the letters after the YouTube domain.
    iPhone ?
  13. Beachbummm
    1,160
    392
    could be that you are in the UK and this video is unavailable outside the US not sure, don't worry about it
  14. Data Daedalus
    1,022
    1,183
    Wembley, London
    Yes, I am in the UK. Hmmm, that might be the case, but I was unaware that YouTube was restricting videos to certain parts of the world.
    Here's another YouTube link, just to double check. This one's actually from stateside, methinks!
    iPhone ?
  15. Data Daedalus
    1,022
    1,183
    Wembley, London
    Actually, I have NO idea where that video's from........maybe not the USA, judging by the funny moped that just sped past as the gate opened.....
    iPhone ?
  16. Sam Spade
    2,036
    1,023
    2017 Prius c
    Works fine for me.
    In BOTH posts where it appears.
  17. Briana Giselle Jauregui
    South Pasadena, CA
    Did. Thank you. Changed battery also.
    I know- "feelings." ;)
    Those were my initial moves.
