HOV sticker loose
Discussion in 'Gen 2 Prius Main Forum' started by tedb, Jan 30, 2006.
  1. tedb
    tedb Member
    111
    Woodland Hills, CA
    I have a problem with one of the HOV stickers; it just won't stay on. It appears that they are made to be somewhat easy to remove. I have no idea as to how I would go about getting a replacement (assuming one is available). Does anyone have an idea for an adhesive that would hold the decal in place -- but allow it to be removed later on -- and would not do damage to the finish?
    Thanks.
    Ted
  2. Peter_C
    Peter_C Junior Member
    39
    Just get a replacement sticker. It is the same form you used to originally get the stickers but check a different box.
    Glueing it down might cause damage to the paint.
  3. jbarnhart
    jbarnhart New Member
    629
    Santa Clara, CA
    Just curious... Was it relatively cold or wet when you put the sticker on? This is the first I've heard of a sticker that wouldn't... stick, that is.
  4. tedb
    tedb Member
    111
    Woodland Hills, CA
    Not that I recall. Three out of four (sticking) ain't bad though!
  5. tochatihu
    tochatihu Senior Member
    9,903
    3,835
    Kunming Yunnan China
    2001 Prius
    If you get a replacement sticker, but sure to "dewax" and dry the area before mounting. Mild dewaxing might be soapy water with a little ammonia; serious is paint thinner (which does not remove the car paint).
