How accurate is your MPG computer vs. your calculator?
Discussion in 'Gen 2 Prius Fuel Economy' started by Wolfman, Dec 8, 2003.
  1. less than 1 mpg difference
    0 vote(s)
    0.0%
  2. 1 to 2 mpg difference
    20.0%
  3. 2 to 3 mpg difference
    20.0%
  4. 3 to 4 mpg difference
    40.0%
  5. 4 to 5 mpg difference
    0 vote(s)
    0.0%
  6. greater than 5 mpg difference
    20.0%
  1. Wolfman
    Wolfman New Member
    1,233
    Williston, ND.
    I'm curious as to how accurate other Prius owners computer fuel economy estimates are vs. what you actually calculate at the pump.
  2. Danny
    Danny Admin/Founder
    7,093
    2,108
    1,174
    Charlotte, NC
    2013 Prius Plug-in
    Edited so as to not show Wolfman's ineptness at creating a poll
    :lol:
    Thanks Wolfman.
  3. Wolfman
    Wolfman New Member
    1,233
    Williston, ND.
    I've already fixed it!! :D (Danny knows what I'm talkin' 'bout)
    So far my consumption computer has been about 4.5 mpg higher than what I calculate at the pump.
  4. efusco
    efusco Moderator Emeritus
    19,891
    1,192
    Nixa, MO
    might wanna put a >5mpg category too.
  5. Danny
    Danny Admin/Founder
    7,093
    2,108
    1,174
    Charlotte, NC
    2013 Prius Plug-in
    I went ahead and put it on there since I don't see Wolfman online anymore.
  6. Wolfman
    Wolfman New Member
    1,233
    Williston, ND.
    Do'h!! I though that I had included that one. Thanx Danny.
  7. Wolfman
    Wolfman New Member
    1,233
    Williston, ND.
    HEY now!! This was my first one in here, and EVERY ONE of them all seem to work differently!!! :wink:
  8. Jerry P
    Jerry P Member
    322
    Waterford, PA
    2021 Prius
    XLE AWD-e
    I've noticed a lot of owners stating that their actuals are lower than the display mpg but mine is consistently .5 mpg higher. Does this get any closer the more times you fill up and reset the display?
  9. FredWB
    FredWB New Member
    331
    San Diego, Colli-fornya
    I'm glad Wolfman did the Poll. As far as I can see I don't have that option. I think polls are a great way to get more people interested and show meaningful data at the same time. And I too find the Yahoo site very tiresome to read.
  10. Danny
    Danny Admin/Founder
    7,093
    2,108
    1,174
    Charlotte, NC
    2013 Prius Plug-in
    Fred - when posting a thread, there will be an option below your message along with the Add an Attachment option to start a poll with your thread. It should be there, at least.
  11. Wolfman
    Wolfman New Member
    1,233
    Williston, ND.
    Yup, they are there. Setting it up is a bit vague, but still easy once this particular softwares quirks are figured out.
  12. JeffG
    JeffG New Member
    94
    Middle Tennessee USA
    As time goes on, the display average and the calculated average seem to be converging. Here are the life time figures for my car after almost 6000 miles.
    Display 48.28
    Calculated 48.26
  13. efusco
    19,891
    1,192
    Nixa, MO
    I hadn't checked my lifetime display against calculated until you posted this, Here's what I go.
    Display (5 fills avg.) = 44.3MPG
    Calc'd = 44.0 MPG
    Not within 2/100 like you, but I'll take a spread of 3/10ths!
    --evan
  14. pat
    pat New Member
    Gilroy, CA
    My calculated mileage is generally 1-2 miles off of the displayed mileage. Sometimes it's higher and sometimes it's lower depending on how aggressively I fill the tank. This is after 2415 miles on the car.
    Pat
  15. JeffG
    JeffG New Member
    94
    On the 14th tank of gas.
    overall calculated mpg 47.93
    overall displayed mpg 48.03
    a tenth of an mpg difference
    :roll:
  16. efusco
    19,891
    1,192
    Nixa, MO
    14th tank!! That should be almost 5000 miles, you must have a long commute or have worked in a couple long trips. I'm at 2700 miles and only about 7 tanks and have had my car since Oct. 20th. My computer isn't quite that accurate, but pretty dang close.
    --evan
  17. JeffG
    JeffG New Member
    94
    Over 6000 miles. I commute 150 miles a day.
  18. aaron-aggie
    aaron-aggie New Member
    I’d be interested for those of you keeping records the difference in amount of gas.
    For example on the last tank you know how many miles you drove and what gas mileage the car is reporting, divding miles by miles per gallon gives the amount of gas the car is reporting to of used. How does that amount compare to what your actually putting into the car?
  19. inventor00
    inventor00 Active Member
    1,131
    60
    Phoenix, AZ
    Glad I found the survey- Thought I was going nuts.
    Last tank computer showed 44 MPG and my calculation was 39 MPG or about 5 MPG overestimated. This involved hills - route 8 from Tucson to San Diego, over 100 degree weather , and some Air Conditioning.
    Also had another tank that was 5 MPG overestimated on the screen.
    Did the A/C and heat affect the difference that much?
  20. JeffG
    JeffG New Member
    94
