How bad is your MPG in the winter time with short trips?
Discussion in 'Gen 2 Prius Fuel Economy' started by koukilights, Dec 4, 2019.
  1. koukilights
    koukilights Junior Member
    Colorado
    I'm currently getting about 30-32mpgs on average and I most of my trips are under 10 miles. It's usually about 35-45 degrees this time of the year and perhaps the gas stations are carrying a winter blend of fuel. Tires are at about 32 psi
    In the summer I could get about 38mpg running the same length trips to work and around town. But since the cold hit it's been noticeably lower.
    My coolant temp (monitored through torquepro) only gets up to about 150 degrees, is that normal? I recently put in a new thermostat, it wasn't OEM but it might have been gates, I'm not totally sure. Should a good thermostat be able to hold 180-190 despite the cold ambient air?
    51,668
    that sounds about the same as i get with mine
  3. egg_salad
    egg_salad Active Member
    545
    426
    Las Vegas, NV
    I bet you're running the heater, too. This effectively establishes the least efficient set of parameters for Prius operation. I'm surprised you're getting as many MPG as you are. When you ask for heat, the ECU runs the engine constantly to get the coolant temperature up. But since the heater core is effectively another radiator, you'll never get the engine up to temperature. Then the ECU runs extra fuel into your (relatively) cold engine, acting like the choke would on a car with a carburetor. Under these circumstances, 30 MPG seems on the high end of what you might expect.
  4. dolj
    dolj Senior Member
    8,383
    4,270
    Wellington, New Zealand
    This is the only thing in your list that stands out to me.
    Try running your tires at recommended pressure + 1 PSI, so that would be 36 PSI Front / 34 PSI rear. It might not make that much of a difference, but it should help a little. at least 2-3 MPG.
    What altitude are you at, and what grade (octane rating) fuel are you using?
  5. fuzzy1
    10,356
    Why Mileage Gets Worse in the Winter | PriusChat
    Do you have snow or other precipitation on the ground? This compounds the normal winter losses.
    It will depend on your driving profile, outside weather, and cabin heat conditions, not just the thermostat suitability.
    Have you tried a grill block to retain more engine heat? Or a block heater to pre-warm the engine?
    dig4dirt likes this.
  6. dig4dirt
    dig4dirt MoonGlow
    1,151
    741
    Lancaster Co PA
    2014 Prius c
    This.
    I rad block my Gen3 and and my "c" (essentially Gen2 engine) for 5 years now and also just
    installed engine block heater.] a month ago.
    My Gen3 gets a 1.2 miles round trip 3 times a day (kiddies to school, and one in kindergarden/half day)
    My "c" gets a 3 miles each way commute to work.
    Engine block heater has raised coolant temps about 30-40f after 1.5-2 hours
    and results have been about 5+mpg for the larger gen3 and a good 10mpg gain roughly for my "c"
    So my "c" has been getting very close to 50mpg still in 30f temps similar to summer mpg.
    ymmv
