How badly screwed am I?
Discussion in 'Gen 3 Prius Technical Discussion' started by blairsie, Oct 26, 2021.
  1. blairsie
    blairsie Junior Member
    greensboro nc
    I’m replacing my head gasket in my 2010. When I was putting the rocker arms back in, I noticed that of of the valve lifters was gone- vanished. I’m working in my driveway and have spent that last hour looking for it, no dice. If I order new ones, will it be an issue. Can I get just one or do I need to replace all? A second, more ominous question. Since I can’t find it, should I pull the head back off the block in case it somehow fell into the cylinder? Do I then need to replace the head bolts again as well. They’ve all been torqued down to spec.
    Feeling incredibly deflated right now. Been preparing for this job for a while now, had it well in hand till this.
  2. ASRDogman
    ASRDogman Senior Member
    6,063
    3,256
    It would be difficult to drop it in the cylinder and you not notice installing the head gasket and head.
    But, you can try a bore scope and look through the spark plug holes....
    A lifter is a pretty big piece to lose, but replacing it with one new one shouldn't be a problem.
    You should not have to remove the head, again.
    And I'm certain you will find it, after you've put eveything back together!
    It's happened to all of us! (y)
    Mendel Leisk and blairsie like this.
  3. Nor'easter
    Nor'easter Member
    158
    96
    New Hampshire
    Good excuse to buy a cheap wifi endoscope that works with your phone. Handy.
    Or fish in each spark plug hole with a small magnetic pick up tool.
    Whatever it is you lost (lifter seems unlikely to me, maybe a keeper?) you can buy individually.
    See here
    blairsie likes this.
  4. ChapmanF
    15,481
    The good news is that the Gen 3 'lifters' (if you are referring to the hydraulic last adjusters that sit underneath the rocker arm at the opposite end from the valve) are self-adjusting and identical, so there is only one part number and you buy it and put it there and it works.
    If you were working on a Gen 1 or Gen 2 (or c) where the intake and exhaust lifters are different and come in 35 sizes each, you would be having a worse day.
    Mendel Leisk, fotomoto and blairsie like this.
  5. blairsie
    greensboro nc
    It was definitely the lifter. I don’t think there are any keepers in there. Otherwise it wouldn’t have fallen out so easily. All I did was tip the head on end to clean and prep the gasket surface.
    #5 blairsie, Oct 26, 2021
  6. blairsie
    greensboro nc
    Found it! After I pulled the head of course
    MacMarty15221 and ASRDogman like this.
  7. blairsie
    greensboro nc
    Do I have to buy new bolts now?
  8. blairsie
    greensboro nc
    I found it in a plastic bag that had been a foot or so away from where I had set the head after it’s initial removal. Subsequently, I took the bag into the house. When I re-pulled the head, and was unable to find the thing, I cleaned my work area. Brought all the pieces that are moisture sensitive inside, cleaned and reorganized my tools, and secured the car. I have to work this afternoon. Pulled all the assorted crap that I’d bought for this project and there it was. Mocking me. And my stupidity. Since I won’t be able to work on it again until Sunday, I erred on the side of caution and ordered a new set of head bolts.
    Last, semi-related note: I have a crappy torque wrench that I got from HB several vehicles ago. I’m not sure I trust it. Given the nature of the project, how necessary is it to replace it? Please keep in mind that I bought the Prius to save money and I’m attempting a repair that may very well be beyond my skills to save money. I appreciate any guidance
    ASRDogman likes this.
  9. rjparker
    rjparker Tu Humilde Sirviente
    7,918
    4,680
    Texas Hill Country
    Glad you found it
    #9 rjparker, Oct 26, 2021
  10. Nor'easter
    Nor'easter Member
    158
    96
    New Hampshire
    That quote is true, but there are endoscopes that aren't medical devices, and I own one. (It works well, but the TOS for the app is a little strange and concerning to some).
    The difference between a borescope and an endoscope is that an endoscope looks out the end of the device, and a borescope looks at 90 degrees (so it can inspect the inside of a bore).
  11. ChapmanF
    15,481
    Every, hmm, cheap skinny inspection camera that I've owned has looked out the end, but has also come with an angled-mirror attachment to clip on the end and supposedly get a side view.
    In the interest of full disclosure, I think I have never ever achieved a usable side view of anything using any of those little mirrors.
  12. rjparker
    7,918
    4,680
    Texas Hill Country
    ***Glad you found it even if you had to pull the head first*** (Response from the Op was delayed by mod)
    The point is a reasonably priced (~$40) borescope/endoscope and your phone does wonders and the Op does not need to be scared off by expensive devices that might otherwise be found.
    For example this Tulsa weatherman uses a wireless "camera scope" on his project bmw in the first couple of minutes. He gets a good look at the piston and walls with decent focus lacking in the sub $20 versions.
    His "camera" seems to be the same Depstech Wireless I have had for the last for years.
    #12 rjparker, Oct 26, 2021
  13. ASRDogman
    6,063
    3,256
    I'm glad you found it, sorry you pulled the head though.
    Did you order a new head gasket also? They are really a one time use item.
    Since you ordered new head bolts, it would be wise to order a new head gasket.
    You certainly don't want it to fail after all your work!
  14. blairsie
    greensboro nc
    Yes, I did. Thanks for the replies
  15. ChapmanF
    15,481
    I have a habit of threading bolts a couple turns back in to wherever they came out of as a way of keeping track of them.
    I recently swapped some EGR components with pre-cleaned ones I had bought from another member. Putting it all back together, I spent probably an hour searching in vain for one last bolt to hold a silly wire harness standoff to the valve.
    Of course I later found it, safely threaded into the hole it came out of, in the other valve.
  16. Mendel Leisk
    38,653
    I've gotten into the habit of setting nuts, bolts and various small removed pieces on an adjacent window ledge, going from left-to-right, as I take them off the car, and below each item or group I put a masking tape label. If it was something as involved as a head gasket I'd "need a bigger ledge" though....
  17. mjoo
    mjoo Senior Member
    1,109
    1,312
    Michigan
    moto g power ?
