How big is the charger AC plug?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Rebound, Apr 14, 2012.
  1. Rebound
    Rebound Senior Member
    3,996
    2,644
    Portland, OR
    [​IMG]I'm installing an outdoor outlet for my PiP charger. I'm getting a weatherproof cover, so I need to know how far the AC cable will stick out from the outlet, including any cable that has to bend in order to make it point down.
    I hope this makes sense: A weatherproof outlet has a hinged cover that snaps over the plug and outlet, and the AC cable then runs through a hole in the bottom.
  2. crewdog
    crewdog Acting Ensign Prius Prime
    493
    388
    Woodstock, GA
    looks like 3 1/2 inches should do.
    I have the box resting on a paving brick to relieve tension on the plug itself.
    2 people like this.
  3. Rebound
    3,996
    2,644
    Portland, OR
    Perfect! Exactly what I needed to know.
  4. stacey
    stacey ☆☆☆☆☆
    115
    23
    Lancaster, PA
    If you find a weather proof cover that is extra deep AND has the hole for the cord on the cover rather than the base, I'd love to know where you got it. I'm sure I could get my cord through the one I have, but I don't like the idea of having to bend the cord as much as I would have to.
    This is what I have: Shop REDDOT 1-Gang Rectangle Electrical Box Cover at Lowes.com
  5. ukr2
    ukr2 Senior Member
    1,010
    276
    31
    Victor, NY
    I'm installing a new Lamp Post in the yard near the right-rear of the PIP, when I park it on the right-side of the driveway.
    I'm planning a Plastic Enclosure that will attach at eye-level to the post and house a double-gang box with Switch and duplex outlet and a hook for the EVSE, to keep it out of the weather. Though it should be weather-proof, the tag says keep away from snow and water. I'm also added a 2nd double-gang bot and wires for future 220vac.
    Wiring 120vac 20amp Power to the Switch, that will power the outlet, which will have a Kill A Watt. Then a right-angle 4' extension to the EVSE with a slot in the bottom for the cord to the car.
    But I'm still looking for the Box !!!
    I'll be away for 10 day and will search more when I get back.
