How can I add a 2nd horn to a 2013 Prius C?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Brad W., Aug 9, 2018.
Tags:
  1. Brad W.
    Brad W. New Member
    Charlotte, NC
    Team,
    Does anyone know of a good explanation (or better yet a video) of what needs to be done to add a 2nd horn to a 2013 Prius C? I've replaced the factory horn with a Fiamm Freeway Blaster Low Tone. I'd like to add the High Tone horn as well. I know that I will need to add a relay for the 2nd horn since the horn circuit is 10 amps and the max draw including both horns is 12 amps (e.g. 2 x 6 amps each). What I'd like to see is a clean, neat installation of the wiring, relay, fuse and where to connect for power. Thank you in advance!
    Best regards,
    Brad
Loading...
