How can I disable Vehicle Proximity Notification System (VPNS) ?
Discussion in 'Gen 5 Prius Audio, Electronics and Infotainment' started by PiperJ3, May 10, 2024.
  1. PiperJ3
    PiperJ3 New Member
    Ohio
    2024 Prius
    Limited AWD-e
    I wear hearings aids and the VPNS noise is driving me crazy... Does anyone know where the sound speaker is located on the new Gen5? I'd like to unplug the speaker for my sanity....
  2. Serenity Now
    Serenity Now New Member
    United States
    2024 Prius Prime
    I don't see that system in the manual. Are you referring to the blind spot monitor? If so, the buzzer can be disabled (manual page 628).
  3. fuzzy1
    10,138
    The system is a federal requirement for EVs, so there is nothing in the manual about turning it off.
    Apparently the name has changed to Acoustic Vehicle Alerting System, at least in the Prime. See page 81 of your 2024 Prime owner's manual.
    For the regular Prius, it is on page 72.
    #3 fuzzy1, May 10, 2024
  4. Serenity Now
    United States
    2024 Prius Prime
    Oh, that's the auditory system that warns pedestrians, since EV is so quiet. However, I think the OP is referring to other vehicles.
  5. fuzzy1
    10,138
    I'm still suspecting he is referring to his own vehicle, and the system that was called VPNS on older models, including on my recently sold 2012.
  6. bisco
    49,357
    if he was referring to other vehicles, why would he ask where the speaker is so he can unplug it?
    is he going to unplug all the gen 5 speakers?
  7. o_intent
    o_intent Junior Member
    55
    2023 Prius Prime
    XSE Premium
    You need to explain it to me like I'm a 5 year-old.
    Are you talking about the noise that warns you about other people and things, or the noise that warns other people/things of YOUR presence?
  8. PiperJ3
    PiperJ3 New Member
    Ohio
    2024 Prius
    Limited AWD-e
    Apparently it is now called Acoustic Vehicle Alerting System. It is the sound that warns pedestrians that Electric / Hybrid vehicle is approaching. I'd like to disconnect the speaker (sound generator) on my new 2024 Gen 5 Prius. Does anyone know where the speaker is mounted so I can access it?
  9. o_intent
    55
    2023 Prius Prime
    XSE Premium
    Copy!
    There is such a speaker. However I must warn you, upon disconnecting the speaker the following will happen:
    - You will then enjoy near silent transport - YAY!
    - You will notice your lock/unlock notifications disappear, along with most if not all the chirps you're used to hearing. Because the vehicle uses the single speaker for all external notifications.
    -The car will sense that you've disconnected the speaker, and then it becomes your wife.
    I've included a couple images for your reference.
    There is still a way of achieving this goal, should you choose to proceed, ask on.
  10. Hammersmith
    Hammersmith Senior Member
    1,301
    1,321
    North Dakota - USA
    2023 Prius
    Limited AWD-e
  11. fuzzy1
    10,138
