how can I eliminate key fob
Discussion in 'Gen 2 Prius Main Forum' started by archibald tuttle, Jul 29, 2023.
  1. archibald tuttle
    archibald tuttle Junior Member
    81
    Rhode Island
    this is the second time the car has been a PIA about turning off. i must have left it on by accident and then left where i was without the key fob because it was already on.
    this is a 200,000 mile 2008 beater oil burner with bad wheel bearings. i am not worried about someone stealing it. this key thing is ridiculous. i just want to set the car up so it doesn't need a key. i know i could have just left the fob in the car but i put it on a ring with my other keys that I have to take with me, my mistake.
    is there a way to just put a switch uner the dash to turn on power and be done with this?
  2. dolj
    dolj Senior Member
    7,645
    3,858
    Wellington, New Zealand
    It might pay to look into why that is and fix it.
    Is the dash failing to light up, even if only intermittently?
    I don't understand this bit, what exactly is the issue? I have my fob on a keyring and have no problems.
  3. Tombukt2
    Tombukt2 Senior Member
    9,075
    1,574
    Durham NC
    Up in Rhode Island I wouldn't think they'd touch this car in the first place well they might sleep in it. I don't know what you mean by a switch just to be done with it if you leave the car unlocked it just stays unlocked I'm not really understanding what you want to switch for You put your remote or fob on your key ring your choice so I'm assuming you always have your key ring with you so the problem is you're getting out of the car and forgetting to push the button to turn the car off well I don't know I yeah interesting for sure.
  4. archibald tuttle
    81
    Rhode Island
    it is not a functional problem to have the fob with other keys but I remove the other keys from the car. whereas, my only solution at the moment is just to leave the damn fob in the car so i don't lose it out of my pocket.
    but, if i don't keep the car keys and the building keys together then I can accidentally leave without the buildng keys. having them together is meant to make sure i don't loose either. but this is the second time in two weeks that they have fallen out of my pocket near enough to the car that it starts and then i get home and find out i don't have them. i really wish i could just change this to have a key instead of a fob. or maybe if i take the battery out of the fob it will only work if i put the fob in the socket. in any event, the size of the fob is what tends to make the damn thing fall out of my pocket. i pull something else out, phone, headphones, etc. and it pulls the damn fob with it. in a key car, the keys wouldn't be in my pocket they would be in the igition. i haven't lost a car key in 50 years and now i'm losing this friggin fob once a week.
    i knew i was going to hate this electric key stuff. it is nightmare.
    is there some way to start the car without a fob? some have some kind of override somewhere.
  5. Tombukt2
    9,075
    1,574
    Durham NC
    I guess you could talk to an alarm guy and have something fabbed up seems to me you're in search of a fix for a problem that's well I don't know man. Where I live I pretty much never take the fob out of the car because I don't have to lock the car I'm near the same age as you living in North Carolina USA in Orange county and I haven't locked this car except when I go out of town like to the big city Raleigh Greensboro Charlotte Pennsylvania etc then the fob is in the car. In the same place it's always stored SKS button is usually turned off under the steering wheel so when I get in the car if I push the electric start button nothing will happen the red key flashes are the orange key flashes and I have to reach down under my legs and push the SKS button because the fob is not in the slot it's hidden in the car now the car will start because the fob is within range of the car in the car but doesn't have to be slotted. And off we go so it's kind of a theft to turn I can leave the fob in the car push the SKS button to off turn off the car get out even a step further I could take the key the physical key out of the fob mounted on my keyring with the keys that I keep with me so I can lock the car with the SKS off with the fob hidden in the car in markets that need that.
  6. Leadfoot J. McCoalroller
    7,162
    6,712
    Pennsylvania
    2018 Prius c
    Didn't the 2nd generation models have a switch under the dash to disable the smart key system?
    I could be wrong about which years had that feature. (our c model uses a plain steel twist key that makes me feel like we dodged a bullet)
    If that's your car, then you'd just leave the smart key system switched off, store the fob in a cupholder or something until you pop it into the slot for driving.
  7. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,788
    2017 Prius c
    Do you wear jeans ?
    I keep the FOB in the watch pocket by itself.
    It ALWAYS leaves the car when I do and NEVER falls out by itself.
    It has been through the wash a couple of times though........and survived the "swim".
    This is NOT a car design problem.
    It is a YOU problem.
    YOU will have the same problem in the next car you own too.
  8. Tombukt2
    9,075
    1,574
    Durham NC
    Or unpush the SKS button and the remote can be hidden in the car and now you push the button it'll start right up when you get out and turn it off and you're going to leave it push the SKS button in and now the car won't start for any regular idiot because he doesn't know to push the SKS button in He also doesn't know the fob is hidden in the car.
  9. dolj
    dolj Senior Member
    7,645
    3,858
    Near enough to the car would be 2 to 3 feet, and the car is smart enough to know whether the key is in the car or not. So, if you dropped the fob outside the car, it shouldn't start. The fact you say it does start, would suggest there is a key inside the car somewhere. Are you able to locate both of your fobs?
    Funnily enough, Toyota installed an SKS disable switch under the steering wheel. Just press it in and the SKS will be disabled. You will then need to insert the fob into the key slot in order to start the car. You will need to use the buttons on the fob to lock and unlock the car.
    I think that could work for your situation.
  10. Tombukt2
    9,075
    1,574
    Durham NC
    Yes think of it as a thick key You don't turn You just insert.
  11. rjparker
    rjparker Tu Humilde Sirviente
    7,961
    4,709
    Texas Hill Country
    If you walk off with the car in Ready having a key instead of a fob won't help. Think about what could happen if a kid or teenager gets in your car when you left it in Ready.
    Put the fob on your keyring!
    You can disable the fob by removing the coin battery or flipping the sks switch which forces you to insert the fob to get a Ready. But you can still leave it running.
  12. dolj
    dolj Senior Member
    7,645
    3,858
    You can't really unless you're leaving the fob in the slot. You need to turn the car off in order to release the fob.
  13. Tombukt2
    9,075
    1,574
    Durham NC
    It's real easy to make the pins stop working in that slot amplifier assembly I've done it on mine so that the slot doesn't lock the remote into place I can pull it out while I'm driving the car or anytime actually those little plastic things they don't work anymore I squash them in to the frame and bent them down I could have taken it apart and done it cleaner but no need.
  14. rjparker
    7,961
    4,709
    Texas Hill Country
    Anybody that would leave the car running by mistake, apparently several times, could leave a fob in the slot.
  15. Tombukt2
    9,075
    1,574
    Durham NC
    Mite be ole timers disease
  16. bisco
    49,435
    trying to convert to a switch will take a lot of modifying, if it's even possible. the for runs through a sensor system to an ecu and car immobilizer. getting around all that will take serious study of the wiring schematics and possibly electronic and software expertise
  17. archibald tuttle
    81
    Rhode Island
    it is very recalitrant about shutting off. i have to hold the button interminably and it won't go off and then i let go and hit the button again only it finally gets around to shutting off so it goes back on. give me the key on the C.
    but good point about taking the battery out of the fob. but then you have no way to unlock the doors without taking the key out of the fob and the key is the only thing that has a hole for attaching to a ring although the detente holding the key into the fob failed on my riginal so i couldn't use that to keep it on the key ring. that is a very dangerous setup for me because if the fob falls off the key I loose it.
    where is the SKS switch? That would have solved my problem as I could never leave anywhere without having the FOB in the dash.
    brian
  18. archibald tuttle
    81
    Rhode Island
    i resemble that remark.
  19. archibald tuttle
    81
    Rhode Island
    the system for keys that has worked for me is to keep building keys and car keys on the same ring. if I park the car and leave the fob in the slot, then i wouldn't be able to go into the building where i'm working. and likewise, if I leave the keys where i'm working, there is no possible way for me to get in the car and leave without them.
    9 times out of 10 they are on my belt loop, but if I have craploads of stuff in my hands and i'm unlocking a door I don't have the ability to put them back on my belt right away. but with car and buidling keys on same ring i'm forced to resolve any oversight right away and I haven't lost a key in lie 50 years. But i'm losoing the fob once a week because the car can drive away without it. (or in the case of the old fob, it had no reliable way to go on a key ring so I didn't keep them together and I think it came out of my pocket when i was changing vehicles and rode a bank up front.
  20. ColoradoCrow
    ColoradoCrow Active Member
    968
    392
    Leawood, KS
    I
    the sks switch is just below and under the steering wheel on the plastic panel. It is a black push button labeled SKS upload_2023-7-30_8-16-47.jpeg this picture shows a car without SKS. The far right is the TMPS reset button SKS would be far left with nothing in the middle.
    upload_2023-7-30_8-19-21.jpeg like this is in the owners manual.Push it so the button stays IN
