How can I fix this? (clock fell into dashboard)
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Soylent, Feb 9, 2010.
  1. Soylent
    Soylent The v isn't a station wagon! It's just big boned
    443
    Fort Lauderdale, Florida
    2013 Prius v wagon
    Hi guys... my clock fell inside the dashboard. I need to get a hand back there to pop it back in from behind. Toyota quoted $100, but I'm thinking this isn't too difficult to do myself.
    I assume that getting access to the radio will give me access to the clock, since it sits right above it. Is there a write-up on removing the radio? This is a 2006 with the standard radio.
    (I found one thread about this dated 2007, but there is no write-up or specific directions.)
    Thanks!
  2. TonyPSchaefer
    14,816
    2,500
    66
    Far-North Chicagoland
    I remember a few years ago people were replacing their MFDs. It seems to me that it's all one housing piece. Perhaps a search for MFD would come up with assembly (dis-assembly) instructions.
    On a lighter note, would it be appropriate to say that it went back in time?
  3. 2009Prius
    2009Prius A Wimpy DIYer
    2,705
    512
    63
    2 people like this.
  4. qbee42
    qbee42 My other car is a boat
    18,058
    3,079
    Northern Michigan
    I was thinking you could use a small mirror to read the clock, or black tape to cover the hole.
    Just trying to help...
    Tom
  5. kohnen
    kohnen Grumpy, Cranky Senior Member
    317
    58
    Fullerton CA
    Buy a watch?
  6. Steamboatsig
    Steamboatsig Member
    337
    Los Angeles
    2013 Prius Plug-in
    hot glue and a stick? small suction cup?
  7. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    I'm not sure, but I think if it hides like that it means we get 6 more weeks of winter.
  8. nadams
    nadams New Member
    louisiana
    I had the same thing happen...I had a temper about something and punched the dash and the clock went into the dash. saved the day by using tweezers and carefully and patiently pulling it out with the tweezers
  9. RobH
    RobH Senior Member
    2,385
    991
    70
    Sunnyvale, California
    Thanks! With those pictures maybe I can identify where my spare yellow snaps are supposed to go. :spider:
  10. USAFRN
    USAFRN New Member
    I have a 2007 Prius touring, and the same thing happened to me; I got 2 stats from work(hospital), brabbed it on both sides, and pulled it forward until it snapped into place. Saved myself a hundred dollars at least! :D
  11. texas.stevens
    texas.stevens Junior Member
    The same thing happened to me! So annoying. One day, I went out (inspired by these forums), took some regular thread and a butter knife, and fixed it. I made a loop with the thread and used the butter knife to push it back and around the clock. I then used the thread to pull it forwards. I was then able to pull it into place with my fingers. Snapped right in! Don't waste your money at the dealership, or your time taking the dash apart.
    2009Prius likes this.
  12. Fool Circle
    Fool Circle New Member
    Delaware
    Just wanted to say, same thing happened to me. Found this forum and used the string technique mentioned above. That, a little patience, and some chop sticks got the job done. Thanks for putting the info out there.
    donbright likes this.
  13. Ripon
    Ripon New Member
    Sydney
    Had the same issue. My rear view mirror dropped off as the glue behind the metal button of that mirror holder could not hold that mirror for a long time due to my recently changed after market windshield glass and glue. Anyway, that mirror accidentally dropped off and fell on the clock. The result: the clock pushed backwards. To fix this clock I just sat on the front passenger seat, and then I used a kitchen fork to slide the fork in the hole, and tilt the clock right side so that my fingers can grab the clock from the side part of it. Then I slowly pulled the clock with two fingers, and snapped back just one side of it (the side where the time and hour buttons are located). Soon that side (where time and hour buttons are located) got snapped on the one side of the holder, the other side also got snapped quickly and smoothly by gentle pull using just fingers.
  14. prius_nerd
    prius_nerd Junior Member
    29
    Georgia, USA
    Thank you to the people who posted above, such as @texas.stevens!
    As you can see here, my clock sunk into my dashboard when I pressed the M button.
    Using 2 very thin knives, I was able to pop it back out where it's supposed to be.
    Be careful not to use sharp knives; when trying to squeeze the clock between 2 knives, it slipped a couple of times. You wouldn't want to slice yourself.
