How can I mod the DRL to have it on at all time? (for 2013 models)
Discussion in 'Gen 3 Prius Accessories and Modifications' started by m3rhkp, Apr 26, 2013.
  1. m3rhkp
    m3rhkp New Member
    I am trying to get my DRL running all time even with low beam or with signal lights on. I know on 2012 models you can put a relay and easily have the DRL running as soon as the car starts. But on 2013 they added a option where you can switch on the DRL or have the DRL shut off manually..
    has anybody looked into this?
  2. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,795
    Undisclosed Location
    I'm relatively new...just bought mine. So anyone prove me wrong or correct me. I'm okay with that.
    But if you want DRL on all the time couldn't you just leave the stalk turned to DRL all the time?
    The lights auto turn off in 30 seconds if you don't physically turn them off, so if you just leave the DRL's on, then they will always be on when you start the vehicle.
  3. m3rhkp
    m3rhkp New Member
    Yes, but I want them to be on with Low Beam engaged. The DRL will shut off if you turn low beam on.
  4. David Beale
    David Beale Senior Member
    5,963
    1,979
    Edmonton Alberta
    Get the manual from Toyota online and modify your car to match the Canadian wiring diagram (which is included in the shop manual - it has both US and Canadian versions in there).
    Note that Canadian cars do not have separate DRL lamps. We use the headlamps at half power wired in series I believe.
    Note also that DRL does not apply when the headlamps are turned on. DRL means lamps on in front when the lights are not turned on.
    What you really seem to want to do is turn on the US separate DRL lamps all the time. That should be relatively simple with a relay activated by "accessory" power.
  5. 4everS2K
    4everS2K Junior Member
    23
    Los Angeles
    So how do we do this?:)
  6. David Beale
    5,963
    1,979
    Edmonton Alberta
    If you can't figure it out on your own using the schematics don't attempt it! It requires some knowledge of basic electrical wiring and electronics. If you just go in and try by guessing you could end up costing yourself a lot of money. There are some very expensive modules in the Prius!
  7. The Electric Me
    9,083
    5,795
    Sorry should of read your post with more care.
    I honestly don't know, but judging from given advice seems like a lot of work/risk for very little change in function.
  8. Paradox
    29,110
    8,589
    201
    2014 Prius v wagon
    Moved to the modifications forum.
  9. El Dobro
    El Dobro A Member
    6,972
    3,209
    Can't help you with what you want to do, but 2012 also has DRLs that can be turned on and off manually, too.
  10. m3rhkp
    m3rhkp New Member
    Hmmm that's interesting to know.
    Why the prius I saw doesn't have this option and it was a 2012
  11. sfv41901
    sfv41901 Masta S
    4,591
    5,291
    Palmdale, Ca
    In order to keep the DRLs on all the time u have o rewire them & this will include removing ur front bumper. There have been a few members tat have talked about this but to my knowledge nobody has co pleated this mod yet.
  12. xliderider
    xliderider Senior Member
    7,842
    3,099
    Honolulu, HI
    Even if you successfully manage to rewire your DRLs to stay on with your low beams they wouldn't dim like properly designed OEM LED DRLs. You would be shining glare at oncoming drivers. Pretty rude just to look cool IMHO.
    xpcman likes this.
  13. m3rhkp
    m3rhkp New Member
    It's actually not that bright to be honest, and thanks to a member on here I got it to work!!
    Drepdom likes this.
  14. bzyrice
    bzyrice Active Member
    805
    324
    West Palm
    How'd u doit relay?
  15. m3rhkp
    m3rhkp New Member
    Just a home made wire, put it over the on the relay :)
  16. bzyrice
    805
    324
    West Palm
    Can u e more specific? I will do this ASAP lol
  17. bzyrice
    805
    324
    West Palm
    And u got any pics of everything on at night?
  18. sfv41901
    sfv41901 Masta S
    4,591
    5,291
    Palmdale, Ca
    What pins on the relay are u jumping?
  19. m3rhkp
    m3rhkp New Member
    Here ya go, looks awsome
    No fog light needed
    Just tap the LED relay to any on going power source. So when you turn on your car, it goes on, when you turn off your car, it shuts off
  20. xliderider
    7,842
    3,099
    Honolulu, HI
    Two things, please post which wire you tapped and also please post a pic of the DRLs straight on at night from above the cutoff level of the low beams.
    I'm willing to bet that the glare from the DRLs will be evident in that the DRLs will appear brighter than the low beams.
    MagnusAG99, vthreee and Dark Knight like this.
