how can I remove the back seat on a 2008 prius?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by benk33, Jul 1, 2015.
  1. benk33
    benk33 Junior Member
    24
    Austin, TX
    I am needing to replace the seat belt on my 2008 Prius and I read that the first step is to remove the back seat cushion. How can I do that? Someone mentioned to pull up on the seat cushion but I am not sure how to do that? When I put my fingers under the seat cushion (the front edge of the one you sit on) I don't feel anything and I worry that I may be forcing something if I pull.
    Thanks for your help in advance!
  2. JC91006
    16,477
    8,394
    The back seat cushions are held in by bolts, the bottom seat cushion, you just lift up from the "middle" of the seat. Pull hard.
  3. hchu1
    hchu1 Active Member
    316
    127
    Houston, Tx.
    2014 Prius v wagon
    Pull up from the middle of each outboard seat, you should be able to then lift up the front and pull forward the lower seat cushion. You'll then have access to the seat belt components.
    #3 hchu1, Jul 1, 2015
  4. JC91006
    16,477
    8,394
    the bottom seat cushion only attaches from the very middle of the entire seat. Pulling up from the middle of each seat gets you nothing.
  5. hchu1
    hchu1 Active Member
    316
    127
    Houston, Tx.
    2014 Prius v wagon
    I just checked, there are two latch point in the forward middle of the two outboard seats. I have corrected my original reply, the rest of instructions stands.
  6. JC91006
    16,477
    8,394
    follow the above instructions.....since he checked
  7. Beachbummm
    Beachbummm Senior Member
    1,160
    392
    lower half of the seat lifts out no tools needed than the rear folding half comes out by removing the bolts on the back of the seats, unhook the seat belts at the top of the seat
  8. gptx
    gptx Junior Member
    Grand Prairie, Texas
    Also you've got to give the cushion a really good strong tug to get it to let loose.
  9. Amadeo
    Amadeo New Member
    Cabo Rojo. Puerto Rico
    On the rear side panels you will find some plastic clips. You have to remove them before removing the plastic covers. There are 3 covers, one on eahc side and a middle one. After all plastic side covers are out, from the side of the rear seat snap it firmly upward. This should be done on both sides. Lift the front part of the seat and take out the seat belts. Remove the back seat on either side.
