How can I tell if my Prius has the brake fix?
Discussion in 'Gen 3 Prius Main Forum' started by zm15, Apr 10, 2012.
  1. zm15
    zm15 Junior Member
    73
    I bought a used 2010 Prius, is there a way to tell if the car has been updated to fix the brake problem??
    I have the Torque app if there's a way to find it in there...
  2. Mendel Leisk
    38,727
    What is the brake problem? Is it a squeak? I'm pretty sure our car didn't get the fix, it's fairly early n the model year. I noticed a slight bit of noise off-and-on, for a while, nothing recently.
    If you've not noticed anything, or are hearing very slight squeaking just when starting out, I'd be inclined to leave it as-is, give it time. I believe it's very minor.
  3. dmvp
    dmvp Member
    364
    Outskirts of Chicago
  4. Paradox
    29,110
    8,589
    201
    2014 Prius v wagon
    He is talking about the 'fix' they rolled out shortly after the Gen III release shortening the time it takes for the transition from regenerative braking to friction braking.
  5. Paradox
    29,110
    8,589
    201
    2014 Prius v wagon
    Have the car plugged in and check the codes, they can see if it has had it done. Also, I would imagine, the service department should be able to see it in their computer via the VIN if it has been done in the cars records.
  6. zm15
    zm15 Junior Member
    73
    I think I'll have them do that.
    I asked the previous owners, and they said they took it in, but weren't really sure if anything was done, do I'd rather just know for sure.
    There's a pot hole at the bottom of a slight hill on my way to work that is pretty much unavoidable and I hit it everyday, while I'm braking at that spot. Before my Prius, I drove an '04 Accord and every single time I hit that pothole I would 'lose' braking. I know it's the ABS loosening bc it think's it slipping - at least that's what I've gathered. I got used to it.
    But it's much much more pronounced in the Prius, thus I was wondering If I'm able to check myself without having to take it in.
  7. Paradox
    29,110
    8,589
    201
    2014 Prius v wagon
    They said they took it in for the 'fix' or just took it in for routine maintenance. Either way, just have it checked, it should take minutes of 'actual work' on their part.
    And don't think the fix takes it away. It lessened it for me, but it does not go away. Even though, I have never had an Oh Crap moment because of it and I've owned a Prius since 06'.
  8. zm15
    zm15 Junior Member
    73
    I asked if they had any troubles with braking in certain conditions and eluded to the recall, they said they never had any problems but they took it in (specifically for THAT i don't know for sure), but i just want to make sure. So i'll have them check.
    Even though I'm the second owner, and it has 38k on it, am I still able to get this fixed if it hasn't been already, because it's a Recall???
  9. samsprius1
    samsprius1 Active Member
    711
    172
    2023 Prius
    Limited AWD-e
    The first time it happens it scares the crap out of you! I have yet to do the recall on my 2010 PKG Five. I'm use to it now. I think you can call just about any dealer with the VIN# and they can tell you whats been done!Enjoy.
  10. zm15
    zm15 Junior Member
    73
    Ha! That it does!!
  11. Former Member 68813
    3,524
    981
    US
    generally, one should not brake hard while going over potholes, regardless of car type.
