How can pulse and glide be bad for engine?
Discussion in 'Gen 2 Prius Technical Discussion' started by okiebutnotfrommuskogee, Jan 9, 2008.
  1. okiebutnotfrommuskogee
    okiebutnotfrommuskogee Senior Member
    1,813
    Tulsa, OK
    A few minutes ago a junior member made a statement that pulse and glide was "very damaging to the engine". Can someone familiar with the workings of the Prius tell me how that is possible.
    I use pulse and glide when traffic allows and have a lot of fun doing it. When gliding, the engine is not running. How can that be hard on it? What about the planetary drive and the motor/generators?
    I have done quite a bit of studying about the system during the last year and can't see that there is a problem.
  2. efusco
    efusco Moderator Emeritus
    19,891
    1,191
    Nixa, MO
    It's not bad for the engine in any way. Perhaps said junior member would like to attempt to justify his/her claim.
  3. okiebutnotfrommuskogee
    1,813
    Tulsa, OK
    Thanks Evan, You are just the one that I hoped would respond. You said exactly what I wanted to hear.
  4. qbee42
    qbee42 My other car is a boat
    18,058
    3,073
    Northern Michigan
    The claim probably comes from the traditional view that starting is hard on engines. Obviously, the Prius doesn't start its engine conventionally, as it starts and stops all the time on its own. Pulse and glide only exaggerates what the Prius tries to do on its own.
    Tom
  5. hill
    8,069
    The only streatch I can imagine the newbie meant might be in reference to pollution ... again, being quite a streatch, and really only applying to PHEV's. Here goes, as I've heard the concern: If the car is hardly running, then it doesn't warm up enough to adequately burn off pollution particles. The theory also brings up concern about lubrication ... where the thought is, if the ICE isn't running, then it must not be getting enough lubrication, which must cause pre mature wear. It's not really a P & G concern. It's more related to running with more EV power.
  6. JimboK
    JimboK One owner, low mileage
    2,817
    187
    49
    Chesterfield, VA
    Did you ask that of the junior member? I'd be curious to see the response.
  7. Danny Hamilton
    Danny Hamilton Active Member
    926
    94
    Greater Chicagoland Area
  8. icarus
    icarus Senior Member
    4,884
    976
    earth
    I believe what the junior poster was suggesting was the old axiom that engines incur 90% of their wear in the first 5 minutes of operation.
    In the old days this was somewhat true in the old days. In the old days, cold starts needed a rich mixture (choke) to start a cold engine, causing potential for oil dilution as well as other problems. In a cold engine the internal parts (pistons, rings, bearing etc) need to warm up to expand to their design sizes to seal and properly.
    The Prius is very different. First, with modern fuel injection the amount of enrichment needed for cold starts is reduced, but more importantly, because of the way the Prius holds the heat in the coolant, it is not really "cold starting" each time it starts. As an engine spins, it really doesn't care whether it is burning fuel to turn or just being dragged along by the wheels to turn.
    In the case of the Prius, above 41 mph, the engine is just spinning along for the ride if no gas is needed. Most cars burn a bit even coming down a long hill with the throttle totally closed.
    Perhaps this clears up a bit of misconception,
    Icarus
  9. JimboK
    2,817
    187
    49
    Chesterfield, VA
    Thanks! I searched around for it quickly during my lunch break but couldn't find it. Meanwhile, Evan beat me to it.
  10. David Beale
    David Beale Senior Member
    5,963
    1,981
    Edmonton Alberta
    I think it was Consumer Reports, that posted on the net their continuing reliability study. In it they stated the Prius was the "most reliable family car".
    That doesn't help you, of course, but mechanical/electronic contrivances DO fail. So relax, let the warranty handle it, and be assured it will probably not fail you again, once they fix it. What you ended up with is called "infantile failure". The most failures occur early or not at all until the unit is very old.
