How can they improve the fuel economy of the next generation Pruis?
Discussion in 'Gen 3 Prius Technical Discussion' started by techman41973, Aug 28, 2012.
  1. techman41973
    techman41973 New Member
    The last redesign was the 2010 model. I'm wondering if they've reach the limit on improving the platform's fuel efficiency.
    It's already one of the most aerodynamic vehicles on the road with low-rolling resistance tires.
    The electric power electronics and electronic motor are already 90% efficient. Lithium polymer batteries are no more energy efficient than Nickel Metal Hydride.
    There isn't much that can be improved from the 1.5 liter Atkinson cycle 4-cyclinder that operates at it's most efficient RPM thanks to the CVT. I don't even see much improvement if they add direct injection. They could migrate down to a turbo-charged 2-cylinder or 3-cylinder, like Ford's new 1.0 liter Ecoboost I3.
    The only areas I can see substantial improvement would be to the regenerative braking system or reducing friction in the CVT.
    They could also switch to an aluminum platform to cut weight, but that would add thousands to the price.
  2. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    I feel Cruise Control is not part of the 'hypermiler' experience yet, it is no smarter than any other car.
    I would like "decelerate" to help you do a perfect glide, no power into or out of the HV battery.
    I would like "accelerate" to give you a perfect pulse, all the acceleration the ICE can give with no drain on the HV battery.
    The PIP proves that more battery power will still yield better MPG even when not in EV mode, so even marginal increases can bump MPG.
    There is no Prius v PIP, and that would be 'easy,' in other countries the battery is in the center console, so a HV battery in BOTH places could be a PIP.
    A Prius C PIP would be harder, hiding more battery is a challenge.
    Engine block heater could use the PIP connection, to reduce cold start times.
    Possible Aero improvements:
    shuttered grill
    Rear view cameras, outside mirrors that fold in
    Variable ride height
    All of those should be cheaper than an aluminum frame.
  3. Paradox
    29,110
    8,589
    201
    2014 Prius v wagon
    The Gen III (2010 through current) uses a 1.8L engine, the 1.5 was used for gen II.
    I wonder just what the will come up with for the Gen IV as well, but if anyone can do something which may surprise us I have faith it will be Toyota and their engineers keeping Prius as the top MPG earner. At least we probably have another 3 years until the gen IV comes out so there is still a little more time to test and experiment.
  4. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
    Yep.
    I too think that perhaps they'll go w/shuttered grill, direct injection, maybe even a smaller engine w/forced induction (super or turbocharging, but that seems unlikely, for Toyota), more aerodynamic improvements and further weight reduction.
  5. Gun owning Prius driver
    397
    78
    Downey, California (Los Angeles Area)
    A smart cruise control thAt would be An awesome idea.
  6. kbeck
    kbeck Active Member
    420
    274
    Metuchen, NJ
    There's tricks coming.
    1. Move to silicon carbide FET transistors in the motor/generator inverters. They are more efficient with less losses and can run at >much< higher temperatures than normal FETs. These are in production now, but weren't five years or so ago.
    2. When #1 is in place, remove or vastly reduce the cooling system for the for the inverter. With the silicon carbide FETs running at higher temperatures, a small fan blowing across a heatsink may be all that's required to keep them in their operating range. Less weight and power for cooling = higher overall efficiency.
    3. The engine is a Atkinson. Yes, it's more efficient than an Otto. However, there are other engine types in development (and, for sure, Toyota won't be saying) that are potentially more efficient than the Atkinson. One of the beauties of Toyota's hybrid system is that it doesn't require that the internal combustion end of the planetary gear run at "normal" engine speeds, so a more efficient engine spinning at higher or lower than "normal" gas engine speeds is possible. If it made sense, you could put a turbine in there. Or one of those low-speed, Carnot cycle engines, if such a one could be ramped up to a decent power level.
    KBeck
  7. ProximalSuns
    ProximalSuns Senior Member
    1,877
    PNW
    Diesel would add about 25% and that's available tech now.
    Only other option is larger capacity battery with less weight.
    The Diesel/EV/Hybrids are the immediate future with HydrogenFuelCell or direct burn hydrogen the final goal of a totally renewable, non-polluting transportation.
  8. John H
    John H Senior Member
    2,208
    557
    More battery, more ev range. probably should have the battery sized for each driver's commuting profile. a 3kwh for 10mile commuters, 10kwh for 40mile commuters, and a 25kwh for 100mile commuters.
  9. cwerdna
    12,544
    2,123
    SF Bay Area, CA
    Sigh... not this garbage again about hydrogen and hydrogen combustion. (n) Better off putting the electricity directly into EVs.
    We already went thru that argument at The Economist: Electric cars Difference Engine: Tailpipe truths | PriusChat. Gotta love it when even BMW killed their hydrogen combustion 7 series. Besides that vehicle's tank losing hydrogen over time and being empty in 10-12 days, to quote from patsparks at BMW Hydrogen Power | PriusChat
    finman likes this.
  10. ProximalSuns
    1,877
    PNW
    Hydrogen combustion is the best end answer for transportation. Their likely is not enough material in the world to build a battery/EV transport system.
    Direct burn hydrogen works now as the BMW Hydrogen 7 demonstrated. Eliminates emissions, eliminates problem of battery build and disposal and runs on entirely sustainable fuel which can be extracted via solar hydrolysis. It translates to aviation and truck transport as well.
    But to the Prius next step, only Diesel can give the Prius a 25% jump as a hybrid possibly higher capacity batteries with no weight gain but that doesn't seem available for the next Prius while clean Diesel is available.
  11. GasperG
    GasperG Senior Member
    1,168
    597
    Slovenia
    2018 Prius
    I would say that gain in efficiency with diesel would be 10% in best case, of course MPG number could be higher than 20% because of higher diesel energy content. But you are forgetting that Toyota created HSD for low emissions first and consumption second. Here in Europe the word is that Toyota is abandoning their low powered D-4D diesels engines (BMW will supply their diesel engines), suggesting that they are not developing new diesel tech.
    Hydrogen can be burned at higher efficiency (than fosil fuels), in fuel cell, problem is hydrogen PRODUCTION efficiency and storage.
  12. Tim Bender
    Tim Bender Member
    134
    44
    I'd say the PIP is proof that there's still a lot of room for improvement.
  13. wjtracy
    wjtracy Senior Member
    11,314
    3,588
    Northern VA (NoVA)
    ...reducing vehicle weight is the only thing I can think of.
    If you follow physicist Amory Lovins of Rocky Mountain Inst. he has a super car concept.
    It is made of carbon fiber.
    Gimme a plug-in "light" with a 3-size batt I will plug it in when I feel like it.
    I love the hypermiling cruise control idea too.
  14. jhinsc
    jhinsc Senior Member
    1,167
    259
    South Carolina
    I would like to see enchancements that bridges the gap between the current Prius and the PIP, where you have a bit more capacity before the ICE kicks in, without the hassle of plugging in, even if it's only double the 1-2 miles we can currently go in EV mode. Also, have the ability to be in EV mode automatically at every stop, and accelerate up to 20 - 30 mph before ICE kicks in is a no brainer for at least 2-3 mpg increase for city driving. Another would be to allow intermittent auto-EV mode driving while cruising at higher speeds should notch up another 1-3 mpg on highway. Other improvements such as direct injection, improved LRR tires, aero improvements, and weight reduction will aid mpg too.
  15. John H
    2,208
    557
    Or increasing the typical number of occupants to achieve greater vehicle passenger miles.
  16. John H
    2,208
    557
    Not being a hydrogen refining expert ... it seems like you could start with natural gas, consume some of it to produce the energy to refine hydrogen from the hydrocarbons, re-sequester the carbon as graphite (and any other nasties), and provide a carbon free transportable hydrogen supply for mobile transportation applications.
    There is an increasing demand for graphite in high carbon steel and batteries. A Leaf Li-Ion battery uses 40kg of graphite according to Graphite - Wikipedia, the free encyclopedia
  17. Codyroo
    Codyroo Senior Member
    1,826
    515
    Pleasanton, Ca
    To do this, Toyota would have to reprioritize their focus for the Prius, as it is designed to be the least polluting car rather than the best MPG car.
    If they did that, they would eliminate the "engine run cycle" that tries to heat the catalytic converter when you start your car. That would help a number of people out with shorter trips, because the car isn't constantly burning fuel to heat up the catalytic converter.
    Better OEM LRR tires for extra fuel economy (Think Michelin Energy Saver A/S instead of stock Yokohamas).
    Weirder/Out there suggestions
    Electronic Drivers and Passenger side mirrors. Have a camera that projects an image onto a screen inside the car that shows you your view from the "Driver's Side" and "Passenger Side" mirrors. This would eliminate the need for the exterior mirrors. I suspect that would improve aerodynamics.
  18. John H
    2,208
    557
    You could also replace the front windshield with a forward facing camera and lower the top, laying the driver in a prone position. This would probably increase crash safety as well, albeit it might increase crash occurance.
  19. fuzzy1
    10,045
    "Better Mileage Now', Scientific American, February 2010, has a laundry list of technologies from a 2008 NHTSA evaluation. The Prius has only about half the stuff on this list. There is plenty of room for more improvement.
  20. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    2,994
    Fort Lee, NJ
