How Come it Only Gets 1 More MPG than a Camry Hybrid?
Discussion in 'Prius v Main Forum' started by cycledrum, Mar 20, 2013.
  1. cycledrum
    cycledrum PSOCSOASP
    8,245
    1,202
    NorCal
    Does Prius v aerodynamic drag affect MPGs a lot?
    Prius v, 134 HP, 1.8L gas engine, only 3,274 lbs curb weight
    Camry Hybrid 200 HP, 2.5L gas engine, 3,435 lbs curb weight
    And Prius v only gets 1 more MPG than Camry Hybrid ?? (42 vs 41)
    Wow that Cd must bite. Or is something up with drivetrain?
  2. wjtracy
    wjtracy Senior Member
    11,324
    3,591
    Northern VA (NoVA)
    Are you talking EPA or Fuelly (real world) MPG difference?
    Lets go with real world if data exists. Recently some real driving v data was posted vs. speed vs. liftback and v was impressive there.
  3. Munpot42
    Munpot42 Senior Member
    1,391
    543
    Santa Monica, Ca. 90405
    The Camry's powertrain has more horsepower, wonder how that helps its' mileage, or if?
  4. mikefocke
    3,701
    1,649
    Sanford, NC
    Try cramming as much stuff into a Camry's trunk as you can fit into a Prius v. Having the shape to do that kills you at speed. The Camry is getting impressive real world mileage according to fuelly. Not like the III though.
    So we see designs that have efficient air flow over their surfaces help immensely.
    cycledrum likes this.
  5. wjtracy
    11,324
    3,591
    Northern VA (NoVA)
    OK here is side-by-side comparison from FuelEconomy.gov
    Prius v EPA=42 Fuelly=42.5
    Camry Hybrid LE EPA=41 Fuelly=40.3
    Camry Hybrid XLE EPA=40 Fuelly=38.2
    Prius Liftback EPA=50 Fuelly=49.3
    So about +2 MPG for the Prius v vs. TCHLE
  6. bisco
    49,507
    i wonder which one has better potential for hypermiling.
  7. cycledrum
    cycledrum PSOCSOASP
    8,245
    1,202
    NorCal
    Can say that again, like 50% more.
    Pretty sure Camry hy Cd is .27 and isn't the v's .29?
    wj's right, fuelly shows 2 more for v. It's funny, when I pick u a rental Camry, the avg FE is often something like 38 MPG for the previous renters ....
    I reset the gage, get it warmed up and boom, shoots up to 43+ for me. Seems the rental car drivers are rookies or leadfoots. I wasn't hypermiling the other day and turned Cam Hy LE back in at 45.8 MPG on gage.
  8. bisco
    49,507
    i wonder how well a camry wagon would fair? would be interesting to see the Cd.
  9. wjtracy
    11,324
    3,591
    Northern VA (NoVA)
    If there is a Camry Hybrid wagon, I am getting one.
  10. xs650
    xs650 Senior Member
    4,539
    1,433
    Northern California
    My 2 cents worth thinks that a Prius owner is more likely to be seriously into the fuel economy thing than a HyCam owner and an XLE HyCam owner to be more into luxury "just drive it" transportation than an LE owner. That could explain much of the Fuelly-EPA difference. between the different models.
    Code:
    					   Fuelly-EPA
    Prius v		  EPA=42 Fuelly=42.5		+0.5
    Prius Liftback  EPA=50 Fuelly=49.3		-0.7
    Camry Hybrid LE  EPA=41 Fuelly=40.3		-0.7
    Camry Hybrid XLE EPA=40 Fuelly=38.2		-1.8
  11. bisco
    49,507
    excellent point.
