How common is the headgasket failure and EGR getting plugged?
Discussion in 'Gen 3 Prius Main Forum' started by Kaptainkid1, Apr 6, 2021.
  1. Kaptainkid1
    Kaptainkid1 Active Member
    308
    247
    Los Angeles
    I wanted a thread to track the headgasket failure on 3rd Gen Prius 2010-2015. Is a headgasket failure a if or just when it's going to fail?
    I also heard the EGR gets dirt and plugged.
    Do Prius owners actually services these parts and clean them?
    Please reply with following:
    Headgasket:
    Year of Prius?:
    How many miles?:
    How many years of ownership before it happened?
    Did you replace the headgasket before engine failure?
    Did you replace engine because it couldn't be saved?
    EGR:
    Year of Prius?
    How many miles before EGR engine code come on?
    How many years of ownership before EGR started to fail?
    Was there any problems following the EGR plug?
    Hopefully this thread will help other 3rd Gen Prius owners track these problems and give an expectation time frame and experience.
    52,046
    unfortunately, threads don't work that way.
    we have no idea how common it is, because there are millions of prius owners who aren't members here.
    toyota does not divulge this information.
    here's my best guess based on spending a lot of time reading posts:
    it is not a when, but it is an if
    most egr circuits reported here show some amount of clogging. it is always worth checking.
    an ounce of prevention...
    otoh, we are not sure what the actual cause is, because toyota updated the rings in 14 and pistons in 15.
    Merkey likes this.
  3. ChapmanF
    18,272
    Some additional information has been accumulated over recent months:
    So the state of knowledge doesn't stay completely static forever. It plods along, just doesn't match the pace of the most avid speculators.
    #3 ChapmanF, Apr 6, 2021
    privilege and Merkey like this.
  4. Mendel Leisk
    41,590
    I’m guessing now BOTH pistons and rings were changed at the same time, sometime in model year 2014: apparently new rings don’t work with old pistons, or vice versa.
    Merkey likes this.
  5. AW82
    AW82 Member
    186
    99
    Madison, WI
    Your second link doesn't work, fyi.
  6. ChapmanF
    18,272
    Thanks, fixed.
  7. MelonPrius
    MelonPrius Senior Member
    839
    516
    Nevada
    I've wondered if I have the new rings or pistons in my car (3/29/14). It could be both, neither, or one of them. I still don't know.
  8. Mendel Leisk
    41,590
    Yeah it’d be nice if it could be determined by VIN; @Elektroingenieur might know?
