How could I run the A/C system from 120v while parked / camping?
Discussion in 'Gen 2 Prius Technical Discussion' started by Tekdeus, Jun 19, 2016.
  1. Tekdeus
    Tekdeus Shifted to Green
    151
    Vancouver
    Hello friends, is there a way I can keep the electronic air conditioning system running with the car engine off, while parked at a RV park or campsite? I'd like to be able to tour some hot climate destinations car camping and take advantage of supplied 120v sources when parked (also have a 12v fridge to keep running).
    Maybe interface a 120v-12v power converter somehow? Is there ANY way to leave the car ON/READY but sustained by outside power (in elec mode) somehow? Thanks for any input
  2. S Keith
    S Keith Senior Member
    799
    329
    AZ
    2003 Prius
    No.
    A/C compressor is 200V and the wiring needed to do it is dangerous at best.
    #2 S Keith, Jun 19, 2016
    Merkey likes this.
  3. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    I do not recommend this, it seems to me that electrocution is bad.
    The A/C is run from the 201 volt battery. If you kept the 201 volt battery charged, the engine should never turn on in Ready. So you want a 120 VAC to 202 VDC charger.
    starting at 15:10 it discusses the A/C electrical system to 16:55
    Merkey likes this.
    52,351
    any particular reason you want the engine off? most campers are very satisfied with the operation.
  5. Tekdeus
    151
    Vancouver
    Would like to not rely on burning fuel when 120v is available. AC system uses a LOT of current and engine cycles on very frequently to keep up.
