How do clean the ERG
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by F_Lv_K, Sep 8, 2016.
  1. F_Lv_K
    F_Lv_K New Member
    Singapore
    As title, anyone have clean the ERG before?
    Method? chemical?
    Thanks in advance?
  2. xliderider
    xliderider Senior Member
    7,869
    3,116
    Honolulu, HI
  3. Mendel Leisk
    38,648
    xliderider likes this.
  4. F_Lv_K
    F_Lv_K New Member
    Singapore
    The video mentioned just show the way to clean the pipe. How about the ERG itself?
  5. xliderider
    7,869
    3,116
    Honolulu, HI
    I believe most people remove the old EGR valve and install a new one.
    Raytheeagle likes this.
  6. Raytheeagle
    Raytheeagle Senior Member
    11,251
    15,481
    Bay Area, California
    2019 Prius Prime
    How many miles on yours? Had it since new?
    To clean the egr, remove the pipe you cleaned then remove the 2 nuts holding the egr valve to the cooler. I did the cooler at the same time. I had replacements for both from the salvage yard.
    When I removed mine it was at 120 k miles. The valve had carbon deposits which can be removed with a brush and elbow grease :).
    The cooler I have been using compressed air to blow the deposits off of the fins inside the cooler. Still getting deposits out.
    What are the symptoms you are dealing with where you decided to clean the egr valve?
    Keep us posted (y).
  7. MeGuinness
    MeGuinness Member
    217
    78
    UK
    Can u show a photo to point out which are the 2 nuts lol,any other things to pull out ?how difficult?
  8. Mendel Leisk
    38,648
    Here's the section from the repair manual:
  9. MeGuinness
    MeGuinness Member
    217
    78
    UK
    Ok so the nuts are facing the car .....got to find someone with small hands then lol
  10. Raytheeagle
    11,251
    15,481
    2019 Prius Prime
    It is a 2 person job:(. But a good excuse to understand toyotas infinite wisdom with the Prius ICE design that includes the egr system:).
    Good luck and PM me if you need any help(y). Getting the new cooler back in is a challenge and I performed a simple modification to help with this:).
  11. MeGuinness
    MeGuinness Member
    217
    78
    UK
    But if I wanna take out just the valve and not the cooler is still a two man job?
  12. Raytheeagle
    11,251
    15,481
    2019 Prius Prime
    Nope. Just need to separate both ends of the valve. That is 4 nuts (2 on each side of the valve). The nuts on the cooler side are a bit trickier, but can be done.
    Good luck(y).
    #12 Raytheeagle, Dec 1, 2016
  13. Rebound
    Rebound Senior Member
    3,964
    2,612
    Portland, OR
    EGR's are pretty expensive.
  14. tankyuong
    tankyuong Senior Member
    1,555
    660
    Central MO
    3hr job. For cooler use carb cleaner and flush it out
  15. Raytheeagle
    11,251
    15,481
    2019 Prius Prime
    Unless you go to the salvage yard;).
    $35 for the egr and $65 for the egr cooler at the auto recyclers in Rancho Cordova.
    I drove there to get them, so no shipping and they had plenty of stock:).
