How do I change the volume on the navigation voice?
Discussion in 'Gen 3 Prius Audio and Electronics' started by mediahound, Jan 15, 2014.
  1. mediahound
    mediahound Active Member
    903
    155
    SF Bay Area, California
    When I have the navigation routing somewhere, I can't figure out how to adjust the volume of the voice. How can I do this?
  2. rsg
    rsg Member
    64
    Harrisburg, NC
    As I recall, it's in one of the setup options - probably for audio.
  3. jhinsc
    jhinsc Senior Member
    1,167
    259
    South Carolina
    I think it's on the touch screen. Look for the "speaker", touch it and the volume control should pop up.
  4. fuzzy1
    10,254
    My speaker icon is on the left edge of the screen, low but not all the way to the bottom. But there are more than one display/audio/nav systems available, so others may be different.
  5. jhinsc
    1,167
    259
    South Carolina
    My speaker icon is similar setup. I wish there was a way to control it from the steering wheel so you don't have fumble with it while driving.
  6. Tideland Prius
    16,195
    SETUP --> Navigation --> Voice Guidance Volume
    It might be slightly different with the HDD version you have but given that it's a Denso unit, I think the instructions should be very close.
  7. mediahound
    903
    155
    Thanks all, found it. It's a bit strange that you can't adjust this from the steering wheel or volume knob.
  8. Tideland Prius
    16,195
    Well it wouldn't know how to distinguish between changing the radio volume and changing the voice guidance. You can, however, change the volume of your call on-the-fly via the steering wheel volume buttons when you're in a bluetooth handsfree call.
  9. Phizley
    Phizley New Member
    Fremont, California
    Since the navi voice doesn't mute the radio, the volume should adjust along with the stereo volume. Or is there a way to set it to mute the stereo when it speaks?
  10. Tideland Prius
    16,195
    It doesn't mute but it should lower the volume. Mine does, even on bluetooth streaming audio. Keep in mind that I have the "legacy" 7" DVD-based nav system, not the flash-based 6.1" Display Audio nor the 7" Premium HDD-based nav (which actually is closer to my system than the 6.1" because it's the same manufacturer that builds both 7" versions).
    The voice guidance should come through the driver's side tweeter/midrange speaker on the dash. (At least that's where mine's coming from)
