How do I check the Battery TEMP=What should be Normal Temp
Discussion in 'Gen 2 Prius Main Forum' started by ski.dive, Mar 30, 2019.
  1. ski.dive
    ski.dive Active Member
    899
    233
    Hutchinson Island,FL. Mt. Snow,VT
    How do I check the Battery TEMP?
    =What should be the Normal Temp
  2. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,790
    2017 Prius c
    You should not obsess over things like this.
    It is not something that you should be concerned about.........in most "normal" situations.
    Finding out where the battery vent and fan is located would be much more useful information.
    Graeme1949 likes this.
  3. TMR-JWAP
    TMR-JWAP Senior Member
    6,266
    5,964
    Columbia, SC
    You can use Hybrid Assistant on an Android phone and a bluetooth OBD device. It provides that information. Typical HV battery temps are ambient at startup and then just a few degrees warmer than ambient after driving for a while. The three temp readings are usually within a few degrees of each other.
    Skibob likes this.
  4. Skibob
    Skibob Senior Member
    2,912
    1,496
    Northern California
    Hold your hand over it. If you can’t hold your hand over it for more than 2 seconds it’s hot enough to start barbecuing . :ROFLMAO:
