How do I clean THIS windshield?!?!?!
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by Paul Anderegg, Aug 18, 2015.
  1. Paul Anderegg
    Paul Anderegg Junior Member
    38
    San Diego, California
    2013 Prius v wagon
    Fixed pattern has made itself very annoying.....can't get rid of it, and my windshield is used to shoot through for LIVE TV broadcasts, so this is a problem for me. Any idea what it is, or what can get rid of it? Stoners Liquid Glass isn;t doing anything to it. Those swirls are not from me trying to clean it either. See YouTube clip below.
  2. Beachbummm
    Beachbummm Senior Member
    1,160
    392
    get a new one
    and your low on gas
    #2 Beachbummm, Aug 18, 2015
  3. RRxing
    RRxing Senior Member
    2,520
    1,791
    NEPA
    Delamination? If still under warranty, get a new one. If not under warranty, get a new one.
    valde3 likes this.
  4. Air_Boss
    Air_Boss Senior Member
    3,953
    1,085
    New Yawk
    Clean the inside. Or if not, replace it.
  5. rjparker
    rjparker Tu Humilde Sirviente
    7,985
    4,731
    Texas Hill Country
    Kind of looks like acrylic wax. Try a acrylic stripper (Zep at Home Depot) carefully - don't get on anything else or a solvent like acetone. You could also try some "Goof-off" Professional Strength (composition attached) which is mainly acetone. Only use the liquid version on a rag. Don't use a spray on. These will strip paint and burn.
    #5 rjparker, Aug 18, 2015
  6. Bill the Engineer
    1,048
    2,278
    467
    At the beach in Delaware...
    Looks like somebody doesn't like you. Is that egg?
  7. bisco
    49,510
    tmz?
    some have had success finding a salvage oem in excellent condition for cheap.
  8. ETC(SS)
    6,557
    Try one of the acetone or solvent solutions mentioned above in a small area near a corner - avoiding paint or rubber and also make sure that the problem isn't on the inside of the windshield.
    Since you live on the left coast, you may not be familiar with something called humidity.
    (It's moisture in the atmosphere----try using the defroster.) ;)
    OK...so if the problem really is on the outside of the car's windshield, then replace the glass, especially since you say you make your living with this car. If it's a work car like mine, and the bean counters at your station won't authorize a replacement, then use a brick and blame it on protesters that your editors don't like. It's not like you have to be truthful all the time-----riiiight? :D
    Air_Boss likes this.
  9. Air_Boss
    3,953
    1,085
    New Yawk
    New keyboard on order...
