How do I connect a Power Inverter to my 2012 Prius III
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Joe Bruno, Jun 17, 2012.
  1. Joe Bruno
    Joe Bruno New Member
    I'm looking to run a refrigerator, a laptop and a lamp during a power outage. Any suggestions as to what inverter I would need and how to connect it.
    Thanks,
    Joe
  2. retired4999
    2,652
    625
    Eau Claire, Wi.
    Sorry I can't help you, but try a site search people have talked about this before and installing converters in the back of the car to do what you ask.
  3. retired4999
    2,652
    625
    Eau Claire, Wi.
    Sorry inverters.
  4. retired4999
    2,652
    625
    Eau Claire, Wi.
  5. bisco
    49,371
    there's a lot of info, but nothing clear and specific enough to just go buy it and hook it up.
  6. retired4999
    2,652
    625
    Eau Claire, Wi.
    Sorry, I know zero about electricity or inverters hopefully some with some real help will chime in!
  7. BSWEET
    BSWEET New Member
    52
    Suisun City
    What size refrigerator are you talking about? If you are talking about a full size (18 - 25 c.f.) your not going to do it for a reasonable price. Even if your talking about one of those small 1.5 - 3.0 C.F. you would probably spend ~ $500.00 just for the invertor. You would be much better off buying a Honda or Yamaha 2000 watt inverter generators for $899.99 delivered. Remember, You should not even try to jumpstart another car with the Prius without possibly frying the Prius inverter. I have a fifth wheel and I have a REALLY BIG battery that I was thing of hooking up a 2000 watt inverter to run my TV and microwave and A/C (not all at the same time) but considering the costs involved, I went with the Yamaha generator.;)
    Just my two cents.
  8. GoldPianoGarden
    GoldPianoGarden Bling Meister
    841
    74
    98
    Brunswick, GA
    I'm with you on that. I bought one almost a year ago, and it's still in the box in the car....
  9. NiHaoMike
    NiHaoMike Member
    98
    16
    Maybe you can find a Japanese market 100V/50Hz sine wave inverter for the fridge? That'll cut down on power usage to about 5/6 by performing V/Hz control. Even better would be a programmable inverter that can perform a V/Hz ramp up and down, although that would not be a common off the shelf item...
    As for rectifier loads (electronics and fluorescent lamps), a common square wave inverter will work just fine. 200W or so is enough to run almost any common portable electronic device.
  10. lettcco
    lettcco New Member
  11. mrtremere
    mrtremere Junior Member
