How do I Disable Tire Pressure Monitor Light?
Discussion in 'Gen 2 Prius Main Forum' started by jmatuska, Jun 11, 2007.
  1. jmatuska
    jmatuska New Member
    I would like to get a second set of wheels for my Prius for a set of studded snow tires in the winter to save having to remount tires every winter and summer. However I would rather not have to buy 4 additional Tire Pressure Monitor Devices for these tires. Is there a way to disable to tire pressure monitor warning light so it is not on all the time when I have my snow tires on? :rolleyes:
  2. hill
    8,226
    If the Idaho laws are like Montana, TAKE THEM OFF in the summer ! ! ! Why do you think are roads look so nasty?! It's the folks that leave them on all year, and never get a ticket. sheesh! My suggestion for defeating the sensor? Trade me your newer model for our '04. We didn't get the sensor. Then you can go merily on your way, digging up the asphalt in the summer :(
    oh, and welcome to prius chat!
  3. mcbrunnhilde
    mcbrunnhilde Opera singin' Prius nut!
    612
    23
    <div class='quotetop'>QUOTE(jmatuska @ Jun 11 2007, 09:22 AM) [snapback]459526[/snapback]</div>
    BillG on the Yahoo 2G group found the best way to deal with the TPMS:
    http://tinyurl.com/2vsg23
  4. mcbrunnhilde
    612
    23
    <div class='quotetop'>QUOTE(hill @ Jun 11 2007, 09:27 AM) [snapback]459533[/snapback]</div>
    Ummm...the OP DOES want to remove snows for the summer. He just doesn't want to have to remount them on the OEM wheels.
  5. slair
    slair Ubër Senior Member
    404
    Lafayette, IN
    <div class='quotetop'>QUOTE(hill @ Jun 11 2007, 12:27 PM) [snapback]459533[/snapback]</div>
    Sounds like someone is a little confused on the correct answer. :p
    he wants 2 different sets of both wheels and tires so he dosent have to remount the tires onto the same rim every 6 months. And because he wants a totally different set of wheels, he dosent want to buy TPS's for the 2nd set. Sheesh!!
  6. jmatuska
    jmatuska New Member
    <div class='quotetop'>QUOTE(jmatuska @ Jun 11 2007, 08:22 AM) [snapback]459526[/snapback]</div>
    I do take them off in the summer, I'm just looking ahead to next winter and wanting to avoid the long lines to get them mounted on my factory rims when everyone is rushing into get them changed. Thus I would have 2 full sets of tires that I could rotate myself at my convenience.
    <div class='quotetop'>QUOTE(mcbrunnhilde @ Jun 11 2007, 08:28 AM) [snapback]459535[/snapback]</div>
    Great link mcbrunnhilde, almost died laughing. I'm guessing there is not another way to accomplish the same thing without the sticky residue?
    Jim
  7. mcbrunnhilde
    612
    23
    <div class='quotetop'>QUOTE(jmatuska @ Jun 11 2007, 11:46 AM) [snapback]459646[/snapback]</div>
    Well, I think Goo Gone would probably work OK... :)
  8. JHSmith
    JHSmith 2020 Avalon Hybrid Owner
    184
    King George, VA
    <div class='quotetop'>QUOTE(jmatuska @ Jun 11 2007, 12:22 PM) [snapback]459526[/snapback]</div>
    Late last year there was a discussion concerning this. The link is:
    TPMS Summary
    There is some good information in this thread concerning what you wish to do.
    I hope this helps you.
    (I also hope the thread link works correctly.)
  9. Allannde
    Allannde Just a Senior
    874
    138
    Washington State
    <div class='quotetop'>QUOTE(John Smith @ Jun 20 2007, 05:31 PM) [snapback]465535[/snapback]</div>
    If for some reason you cannot read what galaxee wrote, if you store your TPMS equipped wheels within 60 feet of where you park your car, your car will think they are still mounted. It seems to take a while for the car to realize that the sensors are not on the car so the warning light does not come on right away when you leave the garage.
    You could also transfer the sensors to the other set of wheels, but this is more trouble.
    You could put a piece of black tape over the indicator on the dash.
    You could just ignore the dash indicator
    Some alternatives.
    Allan
  10. 007Prius
    007Prius New Member
    32
    The easiest way to deal with it is; buy a small tractor tire or ? , insert all the sensors inside tire, air it up and place it in trunk, a storage bin or somewhere, There is a wire going into ECU that needs to be grounded to turn off the light but not sure what wire it would be on a Prius
  11. tochatihu
    tochatihu Senior Member
    9,060
    3,529
    Kunming Yunnan China
    2001 Prius
  12. priusincc
    priusincc Member
    332
    16
    NV
    From reading most of the threads, this looks like TPMS is a nice feature to have, but IMO is not worth the expense to keep it going should something happen to one of the sensors. This is the first car I've owned with this feature, and have survived the last 49 years of driving. To bad, you can't just turn it off like the SKS. The OEM valve stems must have a gasket of some sort; do these ever require replacement? :unsure:
  13. apriusfan
    apriusfan New Member
    6,050
    205
    S.F. Bay Area
    So, to net out everythiing that has been posted to date, there is no way to disable/turn off the indicator light for the TPMS warning (absent getting another set of TPMS sensors and re-programing the new sensors into the system) ? Note that I am referring to disable or turn off, not cover over.
  14. Allannde
    874
    138
    Washington State
    <div class='quotetop'>QUOTE(apriusfan @ Jun 21 2007, 09:30 AM) [snapback]465828[/snapback]</div>
    When you say "no way" you cover a lot of terretory.
    The TPMS ECU is behind the MFD. If you can reach up behind there and unplug the power from it, it will no longer function. If you do that be prepared to plug it back in when you want it to function later. The alternative to reaching up back there appears to be a total dash disassembly including removal of the MFD.
    It does not appear that Toyota provided a switch to turn the TPMS off if that is what you mean.
    Sorry about that. Just trying to help.
  15. apriusfan
    6,050
    205
    S.F. Bay Area
    <div class='quotetop'>QUOTE(Allannde @ Jun 21 2007, 05:27 PM) [snapback]466116[/snapback]</div>
    How about pulling a fuse? Is there a single fuse that provides power to the TPMS? And hopefully doesn't supply power to anything else....
  16. Allannde
    874
    138
    Washington State
    <div class='quotetop'>QUOTE(apriusfan @ Jun 21 2007, 05:59 PM) [snapback]466152[/snapback]</div>
    I have looked through the TM section of the '06 Manuel and I couldn't find any reference to a fuse. A lot of what the Manuel says is trouble shooting.
    Galaxee didn't mention anything about fuses in her summary. She would be a good source if not the best for an answer to this question. I am all elbows when it comes to things electrical.
  17. frank lyons
    frank lyons Junior Member
    dubuque
    sorry to sound dumb but what is an mfd and where is it located?
  18. mr_guy_mann
    mr_guy_mann Senior Member
    3,489
    1,590
    NJ-USA
    MFD is the Multi Function Display- the screen in the center of the dash for the radio, climate controls, and energy meter.
    Anything technical just ain't complete unless it's got lots of acronyms.
  19. runxctry
    runxctry Junior Member
    24
    SoCal
    Electrical tape over the warning light.
