How do I fix chipped paint on my new Prius ?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by joemiata, Apr 12, 2011.
  1. joemiata
    joemiata New Member
    New Jersey
    Greetings everyone, loving my new 2011 Prius except, I need advice on how to fix chipped paint. It went down to what looks like dark primer paint. Blizzard Pearl is the color. You know everytime I look at the car my eyes are always drawn to that chipped section. I assume I need to purchase touchup paint from the dealer. I'm sure there are owners out who can steer me in the right direction (from personal experience) or a good article on the topic.
    Thanks Joe
  2. GBC_Texas_Prius
    218
    38
    gbc texas
    My advice, don't get all wrapped up doing it yourself. We recently had a vandalism door ding and had a professional work on it. He had to stitch it and all that. Doesn't look like new, but your eye isn't drawn to the area. Since it was such a tough case, he charged $150. I'm thinking something as easy as you are describing would be half that.
  3. PriusRoadWarrior
    76
    16
    Wisconsin
    Whatever you do after it is 'fixed', think about having your hood, bumpers, mirrors, door edges, and grill wrapped with the clear 3M wrap that is available. Have it professionally done and you will have bought piece of mind. Note that it is expensive (about $700 for your complete Prius) but is well worth it when you see bugs, grit, dirt and stones just bounce off your car. (no scratches or dings)
    I would pay again to have this done on my next car and it is almost entirely invisible and guaranteed for the life of the vehicle.
  4. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    I feel your pain. Road rash on the front bumper is bad.
    I got the touch-up paint at the stealership and as Tumbleweed suggested, I use a toothpick and build the pit with a few layers of paint. Works well.
  5. sipnfuel
    sipnfuel New Member
    1,080
    174
    So. Cal.
    You'll want to get your color, and then the clear touch up paint.
    I've used a toothpick too. It's difficult. If you get a super fine brush at an art store, you can sometimes do a better job.
    Also one trick is if you screw up the touch up job, if it's less than a few minutes, it will clean off with some vigorous rubbing.
    Just to be safe, for your color, you can practice the rub out technique on the inner door sill that no one sees when the doors are closed. It's good to know if you did a hideous job that you can rub it out.
  6. danvee
    danvee Blizzard Brigadier
    326
    53
    38
    New Jersey
    Joe, you might want to try this company:
    Dr.ColorChip Custom Automotive Touch-Up Paint Kit - Dr. ColorChip: Automotive Paint Chip Repair Systems
  7. Mendel Leisk
    40,602
    At least when/where I asked for it, Toyota's touch-up paint came in a pen. It has a nylon applicator at both ends: one for the base color, and the other clear coat. I found it very easy to dab on controlled amounts, and it flows very easily.
  8. joemiata
    joemiata New Member
    New Jersey
    You guys are great. Thanks for all the help
    Joe
  9. unkprius
    unkprius Member
    152
    With the Toyota touchup paint if the pen gets a little dry it's hard to put a second coat on without gouging the first. If this happens try the toothpick method first before you use the brush if it's on a horizontal surface and the nick is small. I had the fun experience of having the cap of the brush hold some paint after shaking, didn't notice, carefully touched the nick, and at the same instant a big glob of paint came out of the cap and fell directly on the hood.
    A Shamwow was two feet away and got paint duty a second later. Talk about the sweats hitting you as you watch fresh paint run down the hood.
    Only evidence are slight marks where I pressed really hard in panic wiping it up, must have pushed the metallic in the paint on the finish and scuffed it just a tad. Unless it's on a vertical surface, or a really big chip, I'm using a toothpick.
  10. Wowzer
    Wowzer Junior Member
    NY
    Doesn't the prius have a layer of clear coat? Wouldn't you have to use primer if the scratch was too big?
  11. DavidA
    2,342
    1,818
    Chicago western burbs
    They do have a clear coat. Found that out when the body shop had the bill up to $1,580 on repainting the entire right side of my ribbon blue GenIII to repair the vandal's keying damage two weeks ago. Turned out as good as new, or maybe even better! The dealer said they couldn't tell it had been repainted as I took it in for normal service today.
  12. duffasaurus
    duffasaurus Senior Member
    177
    38
    Charlotte, NC
    FYI, Blizzard Pearl is a three process paint. The base coat:040, Pearl: 070 and finally the clear coat. If you use only the top coat: 070 over the primer, the result will not match!
  13. Judgeless
    Judgeless Senior Member
    1,821
    257
    Cleveland, OH
    It if is a small chip, get a match for your year and color of the Prius from the Toyota dealer. The Toyota touchup paint comes in a container that includes an applicator that works well. From 5 feet away it will be hard to tell the small chip was ever there.
    If it is big, you can still use the touchup paint but it might be noticeable. It will not be as noticeable as black on gray. If you are not happy with it, take to a body shop and they will do what is listed above.
  14. The Critic
    The Critic Resident Critic
    3,193
    2,327
    CA
    Once there are any chips, even after they are repaired, I would not get a clear bra. The repaired areas will show up as bubbles once the film is laid on top.
  15. Starkie
    Starkie Junior Member
    83
    Northern California
    True, mine turned out crappy-de-lux grey. :mad:
    I'll just pay the money and have it done properly. :D
  16. yeldogt
    yeldogt Active Member
    810
    313
    NE
    The Toyota book lists the the BP as a two step? The white base and then the pearl top clear coat --- on a scratch it works better to fill it with two coats of base and then overcoat the pearl a couple of times
  17. SoCalBPrius
    SoCalBPrius Active Member
    563
    118
    SoCal
    Why are there so many haters that have nothing better to do but destroy other people's properties that they worked so hard for? Sorry, more of a rhetorical question to let out some emotion:D. While we're on the topic, does anyone know how to get a decent sized door ding fixed other than the obvious(body shop);)?
  18. El Dobro
    El Dobro A Member
    7,075
    3,258
    I saw a guy at a dealer using the bottom of a match out of a matchbook to touch up a car. He said he gets better results than the brush in a bottle of touch-up paint.
  19. txl146
    txl146 Member
    301
    NY
  20. Cyberchomp
    Cyberchomp New Member
    Burlingame, CA
    My first post, and I feel your pain.
    I live in a neighborhood full of hyperactive teenagers who have no further ambition in life than to ride around in Daddy's car and throw eggs at Priuses.
    My '02 Prius has been egged no less than eight times. My '11 Prius (which usually resides in the driveway, behind a gate) has been egged once already. Sure, the police have been out - but if I can't catch the hoodlums in the act, not much they can do...
