How do I grill block
Discussion in 'Gen 3 Prius Fuel Economy' started by alfon, Dec 8, 2009.
  1. alfon
    alfon Senior Member
    1,370
    270
    seaside, oregon
    I took a look at our Prius and it looks like you have to romove the top part of the hood latch area to gain acess to the radiator. Also there is some kind of sensor in the middle of the radiator.
    Is that sensor safe to block? Also what is the best material and what temps do you have to remove the blocker; when its 50 or 60 degrees outside?
    I am really curious to know because I do not know of any 2010 car you need to block the grill to increase miles per gallon. Do the benefits far out weigh any risk? Also I noticed nothing in the owners manual about grill blocking.
    Also what would be difference in MPG's with the a 2010 Prius grill blocked and another 2010 Prius not blocked?
    alfon
  2. TonyPSchaefer
    14,816
    2,498
    66
    Far-North Chicagoland
  3. ken1784
    ken1784 SuperMID designer
    2,940
    1,365
    67
    Yokohama, JAPAN
