How do I keep Scangauge from shutting down
Discussion in 'Gen 2 Prius Main Forum' started by stefano5777, Apr 28, 2011.
  1. stefano5777
    stefano5777 Member
    380
    47
    St. Petersburg Florida
    A little help I just received my Scangauge II today through prius chat. Hooked it up and while under ice throttle it stays on but when I either attemp pulse and glide or straight stealth mode it shuts off? I am in process of reading instructions but if someone can help me out I would appreciate it!
  2. JimboPalmer
    12,470
    6,867
    Greenwood MS USA
    It says something like Gas Diesel Hybrid, choose Hybrid, if you leave it on Gas it thinks the engine turning off is the end of the world.
  3. mikewithaprius
    mikewithaprius New Member
    656
    103
    Rhode Island
    Yes, I believe it goes SETUP - FUEL - TYPE - HYBRID (or so!) from the main menu.
  4. stefano5777
    stefano5777 Member
    380
    47
    Thanks for the quick response!!
    <-------I'm to lazy to look it up :)
    any other tips to optimizing scanguage
  5. mikewithaprius
    656
    103
    Rhode Island
    Just read the instructions carefully on fillups, so you know how the whole process works (the first time is different than the other fillups). That will help calibrate it to precise mpg readings over several tanks. Mine was reading quite high at first.
  6. Azipod
    Azipod Member
    139
    NorCal
    Set it to HYBRID mode. It's in the manual.
  7. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    944
    118
    Los Angeles Foothills
    You will however have to search out the X- Gauge codes. They are quite handy, and once you program them in, very useful!
  8. stefano5777
    stefano5777 Member
    380
    47
    Where will I find the x gauge codes? in manual or in this forum?
  9. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
    Linear Logic publishes very few XGauge values for the Prius. I've asked at http://priuschat.com/forums/gen-ii-...t-gen-ii-xgauges-scangauge-3.html#post1309196 about whether the Gen 2 list is still being updated. That's a starting point for you... Do update that thread if you find out the answer.
    If you're going to use the Google doc spreadsheet, completely ignore the Prius Gen III tab. None (or almost none) of those codes will work. You'll be wasting your time entering them.
    You might also find http://priuschat.com/forums/gen-ii-...angauge-best-threads-mileage-improvement.html helpful.
  10. stefano5777
    stefano5777 Member
    380
    47
    Thanks cwerdna now I just have to decipher what of this stuff means :)
