How do I know if I need a coolant pump?
Discussion in 'Gen 3 Prius Main Forum' started by MilkyWay, Jan 17, 2017.
  1. MilkyWay
    MilkyWay Active Member
    819
    358
    23
    MI
    2010 150K Miles.
    No heat and has a coolant code...
    Additional codes were misfire cylinder 3...
    Additional issue is it seems to have more-than-normal amount of white smoke out of tailpipe.
    My 2 main concerns are the coolant pump and smoke out of tailpipe.
  2. MilkyWay
    819
    358
    23
    MI
    Reservoir not bubbling (on gen 1 I know as soon as you don't see bubbling it is time to switch pump but not sure about gen 3)
    49,469
    head gasket? are you losing coolant? sorry, you're talking about inverter coolant.
    how many miles on her?
    Raytheeagle likes this.
  4. MilkyWay
    819
    358
    23
    MI
    Not losing coolant and oil looks good. Is head gasket common on gen 3....
    I know gen 1 and gen 2 easily go 200K
  5. MilkyWay
    819
    358
    23
    MI
    code is for coolant pump....150K Gen 3 with clean oil....no flow in reservoir
  6. bisco
    49,469
    if there's no turbulence, the pump is kaput.
    it seems to me that the misfire code is related to the white smoke. but if it's not coolant, oil in the cylinder?
    MilkyWay likes this.
  7. MilkyWay
    819
    358
    23
    MI
    Is it similar process as gen 1 where you have to unbolt and loosen front bumper?
  8. bisco
    49,469
    i'm not positive, but i don't think so. see if there's a you tube.
  9. MilkyWay
    819
    358
    23
    MI
    And whoa nelly.....talk about overpriced....gen 1 is a little over $100 on amazon...gen 2 it PLUMMETS down to $50 on amazon...and looks like gen 3 is over $200...Time to call a few junkyards.
  10. MilkyWay
    819
    358
    23
    MI
    And I think I know why price skyrockets gen 3...It's because it also fits 2010 Lexus RX450s....smh
  11. m.wynn
    m.wynn Senior Member
    684
    1,226
    Queensbury, NY
    P0A93? It will help if you can provide the codes the car is storing. It's somewhat confusing as of now since an inverter pump failure and a cylinder 3 misfire would be completely unrelated. An engine coolant temp code, possibly indicating engine water pump failure could be related to the misfire and to the lack of heat/white smoke out the tailpipe. These factors would indeed point toward a head gasket issue. It does appear you understand turbulence in the storage bottle is with regard to the inverter loop. If you're looking for turbulence in the engine bottle, there shouldn't, and wouldn't be any. Apologies if you understand all of this but as I read the thread thus far it's not clear to me.
    #11 m.wynn, Jan 18, 2017
    MilkyWay, Raytheeagle and bisco like this.
  12. David Beale
    David Beale Senior Member
    5,963
    1,981
    Edmonton Alberta
    My guess would be new coolant pump and new ignitor (coil) for cylinder 3. The coil is part of the spark plug connection. If the coil is intermittent you should be able to feel it when accelerating. If it's completely gone not so much, but it would probably cause the "smoke" from the tailpipe (unburned hydrocarbons loading up the cat) and if not attended to soon it could overheat the cat.
    Be happy paying for the pump. It's a part you want to be reliable. 200k mi. is pretty good reliability. My gen 2 engine coolant pump failed at 40k km! It was mechanical (belt driven). The inverter one was electric.
    There are two on the car. I'm not sure reading the posts which one we're talking about. Inverter one is even more important than the engine one for us northerners (engine runs cold anyway ;) ). Just joking, they are both important. No heat would be the engine pump. No coolant flowing in the inverter fill tank is the inverter one.
