How do I permanently default to recrecirculation air?
Discussion in 'Gen 2 Prius Technical Discussion' started by berinker, Apr 13, 2008.
  1. berinker
    berinker New Member
    43
    Santa Barbara, CA
    :angry:I constantly drive in traffic and would like my 2006 Prius to stay on 'recirculation' air but it periodically defaults back to outside air. Is there a way to make it stay 'permanently' on recirculating air?
    Bud
    [​IMG] [​IMG] [​IMG] [​IMG]
  2. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    If you don't use "Auto A/C" mode it'll stay wherever you set it. But on Auto the car will do what it thinks is best.
  3. berinker
    berinker New Member
    43
    Santa Barbara, CA
    I never use the 'auto' mode
    and it still periodically defaults
    Mystery unsolved.
    Bud
  4. qbee42
    qbee42 My other car is a boat
    18,058
    3,079
    Northern Michigan
    It shouldn't do that. It will only default in Auto mode. Either you are unintentionally using Auto, or you have gremlins living in your Prius.
    Tom
  5. efusco
    19,891
    1,196
    Nixa, MO
    Gremlins are not out of the question...at all. We don't use auto in my wife's hihy either but it often reverts to/defaults to (but not always) recirculate...we usually don't realize it until the windows start to fog and we can't figure out why it's feeling so stuffy. We've checked all known settings and yet it still, frequently, does this.
  6. qbee42
    18,058
    3,079
    Northern Michigan
    Evan, it might be a Trunk Monkey. I've never seen them do this, but if they can toss a car jacker off of a bridge, I assume they can mess with your climate control.
    Tom
  7. efusco
    19,891
    1,196
    Nixa, MO
    Well dammit, get your story straight, is it a gremlin or a trunk money, totally different bait to use when trapping....you're wasting my time here!:rofl:
  8. Jiipa
    Jiipa MGySgt USMC (Ret)
    314
    Oahu, Hawaii
    And I've been blaming my wife, guess an apology to her is in order.
  9. TheAnnoyingOne
    TheAnnoyingOne New Member
    318
    -118.15476, 34.112134
    ...what about the recirc. button on the steering wheel being pressed accidentally?:rolleyes:
  10. richard schumacher
    7,665
    1,047
    United States
    Yes, it is very easy to do that. Also note that if "front defrost" is set when the car is shut OFF it will default to "recirc" the next time the car is turned ON. Grrr...
  11. efusco
    19,891
    1,196
    Nixa, MO
    Certainly a possibility worth considering, but in my wife's HiHy with the similar but opposite problem there is no climate control button on the steering wheel. It's actually on the far right side of the center display climate control buttons.
  12. fed123
    fed123 Member
    120
    New Jersey
    2024 Prius Prime
    I've also been concerned about this and have noticed that with the weather warming up, and the entire AC system off, the recirculation will stay on. The moment I use an AC function, even the defroster, the recirculation goes off.
  13. Dave
    Dave New Member
    340
    Santa Cruz, CA
    That's interesting. When I engage the AC, (in auto mode) the recirculation automatically comes on for a while, not off. (I usually run the car in auto mode with the AC off.)
    And as useful as a trunk monkey would be, my Prius doesn't have a trunk. I'm pretty sure it's gremlins.
  14. whodat
    whodat Member
    117
    Aptos, CA
    I have the exact same problem - recirculation mode gets disabled. I've tried lots of different configurations and still the same problem.
    Now I just manual change to recirculation every 5 minutes or so.
    Dave
  15. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    i run in recirc mode most of the time as well. the default is recirc disabled. however, all i have to do is set recirc one time and it stays that way until i restart car.
