How do I post "Green Hybrid" data on my pages?
Discussion in 'PriusChat Website Questions' started by stukid, Nov 4, 2007.
  1. stukid
    stukid New Member
    30
    I notice many posters have Green Hybrid fuel data on the bottom of your pages or posts. How do you do that?
  2. alanh
    alanh Active Member
    1,175
    99
    Phoenix, AZ
    Go into your signature and put
    Code:
    [url=http://www.greenhybrid.com/compare/mileage/car/XXXX.html]
    [img]http://www.greenhybrid.com/compare/mileage/car/XXXX/signature.png[/img][/url]
    Replace the XXXX in both spots with your "Car ID #" -- this appears in the info on the right when viewing your car. You can make it all one line; it's wrapped here to make it easier to read.
    This code shows the graphic and is also clickable, which links to your car's entry at GreenHybrid.com.
  3. HolyPotato
    HolyPotato Junior Member
    92
    Toronto, Ontario
    <div class='quotetop'>QUOTE(stukid @ Nov 4 2007, 07:59 AM) [snapback]534592[/snapback]</div>
    Instructions are at:
    http://www.greenhybrid.com/discuss/f29/dyn...ignatures-1625/
    Of course, first you have to go to the "compare" tab over at Green Hybrid and track your mileage so that you can get a car ID#.
  4. Doc Willie
    1,717
    142
    Out there, somewhere
    And how does this work for CleanMPG?
  5. singingtiger
    singingtiger New Member
    59
    Boulder, Colorado
    Also the link is added at the same time as text
    AND is updated on previous posts.
  6. alanh
    alanh Active Member
    1,175
    99
    Phoenix, AZ
    For CleanMPG.com, use
    Code:
    [url=http://www.cleanmpg.com/index.php?page=garage&displayunits=MPG(US)&viewcar=XXX]
    [img]http://www.cleanmpg.com/garage/images/XXX.png[/img][/url]
    Again, replace XXX in both lines with your car ID -- it's at the end of the web address when you're viewing your car.
