How do I remove the panel under the dash
Discussion in 'Gen 3 Prius Technical Discussion' started by tkennedy, Jul 10, 2011.
  1. tkennedy
    tkennedy New Member
    How can I remove panel under dash on a 2010 Prius III? I need to adjust the brake light switch. Thanks Tom Kennedy
  2. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Hello Tom,
    You don't need to remove the trim (black) piece to adjust. It makes things easier but not necessary.
  3. tkennedy
    tkennedy New Member
    Due to age and physical limitations, I cant reach the switch from the side, but I believe I can from the front. How does this panel come off please. Thanks, Tom Kennedy
  4. frodoz737
    frodoz737 Top Wrench
    4,535
    2,438
    33
  5. carpedal
    carpedal Member
    37
    58
    Centreville, VA
    Here are two documents that may be of help. Note use of plastic panel removal tools.
  6. frodoz737
    4,535
    2,438
    33
    Thanks for those. :thumb: Saved.
  7. xpcman
    xpcman Senior Member
    1,302
    295
    California - SF Bay area
  8. Daigi_
    Daigi_ Active Member
    198
    427
    Hacienda Heights
