How do I Reprogram the Keyless entry for my 2009 Toyota Prius?
Discussion in 'Gen 2 Prius Main Forum' started by Joe Wall, Jun 12, 2019.
  1. Joe Wall
    Joe Wall Member
    243
    52
    Wisconsin
    I went to the dealer and was told that I could only do it at there. I bought my Prius used and the spare set of keys keyless entry didn't work. The Fob lights up when pressed but will not lock or unlock the doors so I am stuck using the key if I cannot find my keys. Anyway to reprogram my keys so I donot need to have the dealer do this?
    52,388
    first, you would have to determine if you have the correct key fob. once you do, search for 'chicken dance' and see if that will work for you. sometimes it does, and sometimes it doesn't.
    alternatively, search around for a locksmith who can do it.
    all the best!(y)
    SFO likes this.
  3. ericbecky
    ericbecky Hybrid Battery Hero
    4,443
    3,351
    Madison, Wisconsin
    If the spare fob never worked, it is unlikely that you will get it to work by doing the chicken dance. Would be nice but I wouldn't bet on it.
    The dealer can program it.
    A locksmith can program it.
    You can buy $100 of equipment and program it. (Plus a few hours of your time setting everything up.)
    In the meantime, you can go to a keymaking place and they can make a copy of the physical key onto a normal key blank so you don't have to use the tiny physical key that Toyota provides.
    Eventually you'll want to get extra fobs.
    And it is better to program them all at once.
    Are you in the Madison area?
  4. WilDavis
    WilDavis Senior Member
    2,493
    2,155
    49
    Sorry, I've only just seen this one (…shouts of "…so what's new?"), but have you checked the 12V AuxBattery? (…I had a similar problem about 3 years ago, and that fixed the problem (…as may be discovered in threads passim) - hope this helps - Wil - Good luck! ;)
    PS: look at @bisco 's sig.
  5. Joe Wall
    Joe Wall Member
    243
    52
    Wisconsin
    If I purchased a new Fob online would I need to go through the same process of having a locksmith or a dealership reprogram it? Thanks!
  6. richmke
    richmke Member
    73
    48
    Milwaukee, WI
    Any fob needs to be paired to the car. Since you don't have a fully working fob, you will need someone with the software to force the car to recognize the fob. If you had a working fob, then it is possible to do the chicken dance with the new and old fob to get the new fob working.
    Used fobs can be paired to the car. However, I think that requires the software.
    I suggest: Get a new fob from a dealer, or a locksmith that knows what they are doing. Make sure you get them to fully reset the car so that you can easily add additional fobs later (max of 5 fobs per car, so while they are at it, you might as well have them fully clear the car).
    Then, you can buy a new fob off ebay from a dealer for $150. With the newly programmed fob, you can program additional NEW fobs using the chicken dance.
    FYI: pay $10 to have a dealership cut the key. I had a local locksmith ruin the key when he tried to cut it.
  7. exstudent
    exstudent Senior Member
    2,214
    905
    Torrance, CA
    A lock smith or dealer can add a New fob to the car, esp if there exists a 100% functional fob.
    When you loose all working fobs, or have incorrect fobs like poster #1 (those fobs were never for his vehicle), or you want to add used fobs to work 100% correctly, you will have to seek dealer help. Few locksmiths pay for the vehicle security licensing that allows them to do a RESET (clear all authorized fobs) and RESEED (add new and used fobs to work 100% correctly).
    If one has to go to the dealer for the RESET/RESEED procedure, it is best to get new (100% virgin fobs) b/c of the labor cost at the dealer. Also, the price difference between used fobs (found on the street and now being sold by someone on fleaBay) and 100% new fobs has shrunk considerably. Just not worth it given the small price difference, esp when facing a few hundred dollars in dealer labor.
  8. Skibob
    Skibob Senior Member
    2,912
    1,505
    Northern California
    Since you have 1 fully working key you can do the chicken dance using your fully working key to program the new key. Somewhere in the thread people started assuming you didn’t have a fully working key. I read your posts as you do.
  9. Joe Wall
    Joe Wall Member
    243
    52
    Wisconsin
    Sorry, but what is the chicken dance? I do have one functioning Fob. The keyless entry does work but hoping to get at least one keyless entry working.
  10. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    #10 fotomoto, Jun 20, 2019
    Joe Wall and Skibob like this.
  11. Skibob
    2,912
    1,505
    Northern California
    So do you or don’t you have one fob that works completely? I can’t tell from this post.
  12. Joe Wall
    Joe Wall Member
    243
    52
    Wisconsin
    I DO. I do have one functioning Fob. I have another spare Fob that doesn't work
  13. Joe Wall
    Joe Wall Member
    243
    52
    Wisconsin
    I tried it with the Fob that wasn't working the first and last options. However, neither procedure worked Do the Fobs have a battery? It works to start the vehicle but keyless entry won't work and got to procedure C step 9 and didn't work after this step.
  14. fotomoto
    5,639
    3,815
    So. Texas
    Yes the FOB's have a battery. You'll need a small screwdriver to access it. Search youtube for replacement video.
    The new FOB can't be a used unit/seeded with another car and the car can only seed 5 FOB's total counting the original two.
  15. Joe Wall
    Joe Wall Member
    243
    52
    Wisconsin
    I also wasn't sure on SKS and skipped Procedure B because it talked about a Smart key.
  16. fotomoto
    5,639
    3,815
    So. Texas
    SKS is smart key system. AKA keyless system that doesn't need to be inserted into the dash to start the car. The SKS fob can stay in your pocket, purse, etc. Is that what you have?
  17. Skibob
    2,912
    1,505
    Northern California
    If you have SKS there is a button at the bottom of the dash under the steering wheel to turn it off. There are 2 distinct chicken dances one for SKS and one for non SKS. You need to know what one you have before you start.
  18. Skibob
    2,912
    1,505
    Northern California
    You don’t even know if the fob has a battery? I suggest you read the owners manual before asking for any more advise.
    exstudent likes this.
  19. Joe Wall
    Joe Wall Member
    243
    52
    Wisconsin
    Changed battery and light works I'll try it again
    Skibob likes this.
  20. exstudent
    2,214
    905
    Torrance, CA
    I would add: read the owners manual in its ENTIRETY!!!
